Clutch Diaphragm Strengths
3 replies to this topic
#1 bluemini1979
bluemini1979
  • 619 posts
  • Local Club: Colchester Mini Club
Posted 17 April 2016 - 03:03 PM
Hi
How heavy is a orange diaphragm for pre veto clutch. I've got a grey one at the moment as it was recommended for my engine spec but I have since made it a little less Leary so won't be needing the strength. Just wondered how much stronger the Orange is over a standard diaphragm.
#2 carbon
carbon
  • 2,590 posts
Posted 17 April 2016 - 04:17 PM
Brown (std for 850cc) = 540 lb
Green (std for 998cc) = 708 lb
Blue (std for 1275cc) = 854 lb
Orange ('rally') = 1178 lb
Grey ('full race') = 1280 lb
Above numbers taken from Des Hammill's 'The 1275cc A-Series High Performance Manual'
As a rough guide when using above diaphragms with a well set up standard clutch plate the torque before slip occurs is about 10% of the clamp load. So a blue spring should cope with up to about 85 ft-lb.
#3 bluemini1979
bluemini1979
  • 619 posts
Posted 17 April 2016 - 06:22 PM
Thanks. Orange will do for my 1310 turbo running standard boost then :)
#4 mini13
mini13
  • 3,810 posts
Posted 18 April 2016 - 02:09 PM
should do,
although they can vary a fair bit from  cover to cover, the orange should be ok for about 130 hp, a freind of mine has been putting 150 through one, although its very borderline.
personally an orange is the strongest diaghram clutch i would run on the road, after that i would go to a verto with two springs stacked on top of each other ( the RTS). this is a good way of getting a strong clutch as it does not load up the crank thrusts like a diaghram clutch, as a rough guideline, two 1300 verto springs will give 1500ish lb of clampling, and two turbo springs circa 17-1800lb.
