Has anyone ever repaired the worn-out ball on the end of the clutch arm?
Clutch Arm.jpg 76.69K
3 downloads
I could easily build the end up with steel or stellite and grind back to a ball but was wondering if anyone has experience of doing it or it being done?
Do you think the welding process will weaken the heat treatment of the arm significantly?
I would buy a new one but everywhere is out of stock unless some one knows of a supply.
The other alternative is to fit the racing version from minispares but I'd have a much bigger job of getting the bell housing off to do this.
Thanks in advance.
