Working Out Boost Pressure With Pulley Sizes
14 replies to this topic
#1 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 24 April 2016 - 05:36 PM
How do you do it? Would like to know what boost is with an m45 eaton charger with 17% & 19% reduced pulley.
#2 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 26 April 2016 - 12:17 PM
I assume, due to the lack of response its not an easy one to calculate. Presumably people that quote their psi without a gauge are talking a load of twoddle.
#3 jeebz
jeebz
  • 155 posts
Posted 26 April 2016 - 12:35 PM
I'm not sure on this, I would have assumed there is more work on this been done by the BMW Mini guys. But that's 16V not 8V heads.
#4 jeebz
jeebz
  • 155 posts
Posted 26 April 2016 - 12:41 PM
This is the only thing I can find on this forum, not sure how accurate it is.
http://www.theminifo...duction-pulley/
#5 podifold
podifold
    Suck through sucks
  • 376 posts
Posted 26 April 2016 - 02:07 PM
BOOST CALCULATOR
#6 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 26 April 2016 - 04:52 PM
As it's a positive displacement supercharger it will depend on engine cc not just pulley size. The calculator linked above certainly looks useful.
Phil.
#7 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 26 April 2016 - 05:16 PM
BOOST CALCULATOR
You read my mind. Can't open the link though, well it does open but the content doesn't load. Your CR calculator did the same thing before.
Edited by HUBBA.HUBBA, 26 April 2016 - 05:22 PM.
#8 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 28 April 2016 - 03:36 PM
Out of interest, presumably the bigger the engine and the more volume it can intake the lower the boost pressure would be and there would be less of a pressure build up?
#9 podifold
podifold
    Suck through sucks
  • 376 posts
Posted 28 April 2016 - 03:58 PM
Exactly.
#10 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 28 April 2016 - 04:47 PM
Edited by HUBBA.HUBBA, 28 April 2016 - 09:04 PM.
#11 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 02 May 2016 - 03:26 PM
Jon,That boost calculator is great. was trying to do it on my tablet, but now realise it works on my laptop. Out of interest what's the difference between a SW5 - 07 and a SW5 cam? I thought they were the same.
Playing around with the inputs on the calculator, is the better the cam (letting more air flow in,) the lower the boost?
#12 podifold
podifold
    Suck through sucks
  • 376 posts
Posted 04 May 2016 - 09:17 AM
The difference in the cam specs were measured by AC Dodd and can be found here:
http://www.theminifo...identification/
The calculator factors in a a 5% reduction in boost for every 10 degrees of camshaft overlap. So yes, as a general rule hotter cams run a slightly lower final boost figure.
#13 Grahamxx
Grahamxx
  • 188 posts
Posted 18 June 2016 - 09:37 AM
With a standard supercharger pulley, 1380 engine  we're seeing 11psi
Graham
#14 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 18 June 2016 - 08:50 PM
Graham
Suck or blow?
#15 Grahamxx
Grahamxx
  • 188 posts
Posted 19 June 2016 - 03:37 PM
Graham
Suck or blow?
Suck
