Hi everyone. Some much needed assistance please.
Please bear with me. Bit of a odd one maybe?
Changed blown head gasket, did oil and filter change at the same time. Cranked over with no spark - no oil pressure. Orange light on and oil gauge reading nothing. After a bit of thought, removed head to check head gasket did have clear oil holes (you never know). All ok there. I thought maybe air in oil feed somewhere. (We were towed home, up and down some steep hills, so though oil might have left pump. Re-primed pump, loosened oil filter, turned over engine to make sure oil was moving. Oil light went out and pressure up to 70lb. Oil coming out of gallery on block. All reassembled - turned over without spark and no oil pressure again. So, same process and oil pressure back. Tried a few more times, all was ok, so fired it up. Ran for about 20 mins at 65/70lb no fluctuations. Left for 2 hrs and spun over again (with no spark). No pressure again. Took turning it over for about 20 secs to register pressure. Went back after another few hours and no oil pressure at all. At this point car put back in garage!!!!
Oil pressure has never been an issue before. Engine only done 3k miles. What's everyone's thoughts please. All ideas are welcome. Thank you
Edited by minijack67, 25 April 2016 - 09:25 AM.
