I have a 123 distributor fitted to my 970 Mini Cooper S engine. I am running it on F curve after sessions on the Dyno. I bought the 123 from Minispares UK (their P/N C-27H7770 ) about 2 years ago, but lately I have been getting the odd Spitback(backfire) out of the carb (HIF44) at about 3000rpm and on Highway cruise mode. It doesn’t do this at full throttle operation. This may occur once an hour on a trip as a series of 1 or 2 pops, but I cannot make it happen with my input: it just happens. I can understand if the engine was cold, but this happens when it is up to operating temperature. I have a BBW needle in the carb. This was settled on after prolonged highway driving with an AFR meter in the exhaust. It almost seems like the mixture is lean when the spitback happens, but it happens so fast that I don’t have time to play with the choke to richen it up. I have renewed all intake gaskets, but no difference. I don’t have any manifold leaks, and the car is not fitted with a power brake booster or PCV valve.
The distributor doesn’t have a vacuum advance fitted to it, and I was wondering if fitting one may help my cause. New spark plugs don’t help; neither do new HT leads and distributor cap and rotor.
All compressions are 160-165 psi, and I use 97 octane unleaded fuel with valve additive. All valves were replaced with new ones about 6 months ago, along with brand new guides and double valve springs, I am using N7Y Champion spark plugs, as the N9Ys seem to be a bit too hot. I pulled them out today and they are all a nice ash brown colour. The car goes really well: this is the only bother I have at the moment.
Anyone else had this type of problem?
