Flywheel/crank Damage?
9 replies to this topic
#1 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 27 April 2016 - 09:05 PM
Hiya guys, just been stripping the clutch down to try find out why it's been slipping, found out the oil seal was leaking, but found this on the crank tail and on the flywheel, flywheel is only just a year old and is the mini spares ultralight flywheel, crank was all redone/reground same time as I brought flywheel , crank and flywheel where balanced together.
Engine has only been built a year and only done around 5k engine is producing 110/115bhp.
Is the flywheel/crank scrap ?
Dan
#2 Carlos W
Carlos W
  • 10,114 posts
Posted 27 April 2016 - 09:11 PM
Is it verto or pre verto?
#3 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 27 April 2016 - 09:13 PM
Sorry forgot to add, she's pre verto
#4 Cooperman
  • 23,305 posts
Posted 27 April 2016 - 09:18 PM
It looks as though it was not fully tight and has 'fretted' quite badly.
From the photos it sure doesn't look good.
#5 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 27 April 2016 - 09:29 PM
Flywheel was torqued and flywheel bolt was tight to undo, and flywheel was a Bugger to get off, but something Defo wasn't right, best course of action ? Crank tape and lap it in and hope for the best ?
Dan
#6 Cooperman
  • 23,305 posts
Posted 27 April 2016 - 09:39 PM
Hard to say without seeing it close up. It's a bit of a 'judgement call' as a 110bhp+ engine will be revving at 6000+ rpm and any failure at those revs will be catastrophic.
I think a new flywheel would be sensible, but the crank may be OK if the new flywheel is lapped onto it. The crank could possibly be metal-sprayed and re-ground, but a replacement crank might be both cheaper & safer. Presumably it is all fully balanced and that would need doing again.
#7 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 27 April 2016 - 10:00 PM
Ok thanks, I shall try save them, if not I will order a new flywheels and hope the crank can be saved.
Thanks Dan
#8 Cooperman
  • 23,305 posts
Posted 27 April 2016 - 10:08 PM
Keep your fingers crossed!
#9 GraemeC
GraemeC
  • 7,439 posts
Posted 28 April 2016 - 05:13 AM
There looks to be some quite deep gauges on the crank near the primary gear. I'd hazard a guess some crap has got on there at reassembly and got trapped, stopping the flywheel mating properly with the crank. Although it has held tight (the crap acting as a key) it's still vibrated and fretted.
With care and attention you may save it, I'd certainly be trying. If not successful don't think you'd end with catastrophic failure, it may just fret worse next time.
#10 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 28 April 2016 - 06:27 AM
Ok thanks I shall see what happens, will keep you updated
Thanks Dan
