R1 wiring loom problems
Posted 27 August 2006 - 09:09 AM
are anyof you suffering from any problems becauseI have just blown my third ECU !!
Z Cars check everything out last week and couldn't find anything.and re-did the wiring loom..if it wasn't for my cutoff switch I wouldn't have a car as the wiring loom sarted to spark and smolder and the ECU got redhot and the cockpit filled with smoke !!
Are any of you using a different management system or have you made a complete new loom ?
Responses would be greatly appreciated as my sense of humour has had a major dent as well as my bank balance and I would like to complete a journey without being trailered home (I could have bought a TVR and a tow truck ).
Cheers guys
PS the car is the dogs danglies when it does run !
Posted 27 August 2006 - 09:48 AM
i have three lives ignition injectors ecu they all have separate fuses so if i get probs and a blown fuse i can tell witch circuit it is at fault
also if the bike had a yamaha alarm there is a horible little black wire with is actualy a live
Edited by koss, 27 August 2006 - 09:56 AM.
Posted 27 August 2006 - 09:58 AM
Im just finishing my loom off now but cant really offer any advice as im not familiar with the R1 setup but keep us posted.
Posted 27 August 2006 - 03:45 PM
2002 injection
I've had 3 different problems now:........
Day 2 of running..........misfire under load...a friend traced with a meter back to ECU where the resistance was high...got a new ECU and did 100 miles with no probs.
3 weeks ago on my way to first track day just finishing overtaking a line of traffic and no power....managed to get back in and turn off road without causing any embarrassment...blown fuse at the solenoid and blown ECU.
Managed to get another ECU ...picked up car from Z Cars on Friday...they have checked everything and "re-did" the wiring loom..trailered it home...3 miles yesterday and melt down !!
I will look at the loom once I have spoken to Chris on Tuesday.
The loom was modified by Chris in the first instance.
I have a Digidash so can see the charge going through which seems normal
cheers John
Edited by R500OLE, 27 August 2006 - 03:46 PM.
Posted 27 August 2006 - 05:33 PM
i have seen this happen before on a bike an early r1 it had bin down the road on its left hand side and damaged the flywheel cover, the cover was replaced and other repairs few weeks later it blew a fuse then another one.
one of the ones on the starter relay.
eventualy he put a larger fuse in and hey presto the ecu started smoking turnd out to be a short behind the caseing on the fly wheel.
on later r1s the voltage reg is on its own circuit where as the early ones had 2 voltage regs inside the ecu on inspection of his old ecu (cut open) the tracks and both regs were burnt to a crisp
if you can tell me what wire or pin out the ecu your mate looked at it will help i have all wireing diags us eu uk
for the r1 on my pc
or ask here R1-Forum.Com - ignition/ tci problem
Edited by koss, 27 August 2006 - 07:29 PM.
Posted 27 August 2006 - 09:33 PM
many thanks for the info....you are giving me some excellent help.
the feed for the digidash is now from one of the injectors...originally taken from a coil but the revcounter didn't work...
..after the starter solenoid blew on the 2nd time a larger fuse was put in...hence the meltdown of the ECU....
Atleast we can start looking in a different direction now
I don't have any spare time for the moment but will try to get some help in looking into this...will let you know the outcome .
many thanks John
Posted 28 August 2006 - 07:53 AM
Hi Koss
many thanks John
Good luck with the problem, But i dont envy you trying to find it as R1 ecu's cant be cheap to buy at the rate you are going through them??
Posted 28 August 2006 - 08:40 AM
I will start looking for another ECU ...again
John
Posted 28 August 2006 - 12:42 PM
ian
Posted 29 August 2006 - 10:33 PM
Are you struggling to cantact chris as he has been having trouble with his phone line for a while as it was engaged solid all day today??
Posted 03 September 2006 - 12:17 PM
Hi Mark,
I got hold of Chris on Tuesday and am getting a new loom to try again....managed to get hold of another ECU so am waiting for that to arrive .
I'm away for a few days so have shut the Mini in the trailer and will attempt to try again with some help I hope as I am not confident myself...will be following Koss' advice and will let you know the outcome
cheers John
