Linishing And Dressing Welds Back
8 replies to this topic
#1 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 29 April 2016 - 02:59 PM
What do people use. My angle grinder with a grinding disc is a bit harsh. What should I use for a nicer finish? I've done a search for linishing discs but don't know what is correct and/or if they are sanding flaps?
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,080 posts
  • Name: Neil
Posted 29 April 2016 - 03:31 PM
Now personally i knock the welds back with a grinding disc or cutting disc depending on where the weld is situated. I then finish off with Roloc discs.
http://www.3mdirect....AQ&gclsrc=aw.ds
Some people use flapper discs but you need to be careful with these as its very easy to thin the metal.
Awkward corners i use Carbide rotary burrs
http://www.banggood....yL5MaAt8-8P8HAQ
Other peeps use belt sanders like this
http://www.thoritedi...DmPoaAoAA8P8HAQ
#3 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 29 April 2016 - 04:22 PM
Cheers for that. What do the Roloc discs attach to and what grade do you use?
#4 Carlos W
Carlos W
  • 10,114 posts
Posted 29 April 2016 - 06:40 PM
I use flap discs, just take your time, heat is the enemy
#5 sonikk4
sonikk4
  • 16,080 posts
  • Name: Neil
Posted 29 April 2016 - 07:10 PM
Roloc disc holder
https://www.cromwell...uk0saAp1g8P8HAQ
i use 36 grit discs to polish the weld flush and then on exterior panels 60 or 80 grit to finish off.
#6 Davey3legs
Davey3legs
  • 36 posts
Posted 29 April 2016 - 07:12 PM
Flap discs just ordered loads for my next project.
#7 R1mini
R1mini
  • 1,387 posts
Posted 29 April 2016 - 07:25 PM
I rarely bother finishing anything, unless it's needed for painting in a place that is on show
#8 Tommyboy12
Tommyboy12
  • 2,255 posts
Posted 30 April 2016 - 02:02 PM
Agreed. I only dress welds on the shiney side. I didn't dressed my floor pan or sill repair.
Edited by Tommyboy12, 30 April 2016 - 02:02 PM.
#9 The Otter
The Otter
    The artist formally known as j322overthetop
  • 620 posts
Posted 30 April 2016 - 04:46 PM
If I can get to them easy I'll use a grinder with a flap disc to get them most of the way there then finish off with my B&D Powerfile, or if it's an awkward spot I might use a carbide burr and/or the Powerfile. I've used the Powerfile loads on the recent lot of welding on my car and found it to be very useful and gentle/precise enough to not end up grinding away too much metal.
Edit: as others have said, I wouldn't bother getting structural/hidden welds flush as you're only taking off more metal and potentially weakening things, but I always get them 90% ground down so there's no big obvious bits bulging out.
Edited by The Otter, 30 April 2016 - 04:48 PM.
