Hif44 Carb Plumbing
3 replies to this topic
#1 chrisn89
chrisn89
  • 113 posts
  • Local Club: BOGMOG
Posted 30 April 2016 - 05:56 PM
I know what you were thinking when you seen the title... another guy that didnt do the search...BUT
I know the basic plumbing as per all the pics - fuel, overflow and breather... but i cant remember ever seeing this. The HIF44 i picked up for my clubman estate build has two vac points on the carb alone and also has another pipe on the opposite side of the fuel in.
Why and what for? calling on you lot as i cant remember these on the last one i had.
Also all the hoses are temporary to try and run the thing before the rear subframe and whatnot is finished. the fiting to the bottom left is just a gauge to set the regulator on the filterking
Cheers,
Chris
Edited by chrisn89, 30 April 2016 - 05:58 PM.
#2 59 Speed
59 Speed
    Formally know as Smackfiend
  • 674 posts
Posted 30 April 2016 - 08:24 PM
Is fuel going through that hose?😳
(Is it fuel compatable?)
#3 chrisn89
chrisn89
  • 113 posts
Posted 30 April 2016 - 09:06 PM
Yeah it's fine it's gear we use at work for low pressure testing on fuel oil and the likes so no concern. Plus it's only temporary. Once the rear subframe goes in the proper gear will be going in. Any idea on that right pipe sticking out the carb?
Chris
#4 Ethel
  • 26,073 posts
Posted 30 April 2016 - 11:49 PM
The big "vac" is for the part throttle weakening device. It connects via a short hose to a pipe on the s, above the overflow.
It could have been one of a multi carb setup if the extra pipe is a fuel inlet/outlet.
