1978 Clubman Fwd Hayabusa Turbo
19 replies to this topic
#1 proutyc
proutyc
  • 16 posts
Posted 02 May 2016 - 02:59 AM
Just started a winter project down in NZ.
The mini is a 1978 Mini Clubman with Metro turbo discs and 4 pots.
We're installing a hayabusa turbo using a Promotive diff kit, We mocked it up a few weeks ago and its appears we're going to fit it in the clubbie.
Wheels are 13x7 and had the standard upgrades like adjustable arms and camber/toe plates.
Hope to have the front subframe out this week and then will start to fabricate the engine mounts.
We are using the Hayabusa as I have a turbo Hayabusa kitcar and am using the Gen2 Electric to reflash the ECU for all turbo functions. The Hayabusa ECU will also control all the electrics. We will see 225hp on low boost but maybe a little more on track days
Attached File  094.JPG   131.18K   20 downloads
Attached File  095.JPG   122.32K   19 downloads
Attached File  005.JPG   66.41K   78 downloads
Attached File  001.JPG   63.23K   48 downloads
The Engine has had APE head studs, overdriven oil pump gear, billet shift shafts. Undercut transmission and Forged Turbo pistons
Attached File  002.JPG   39.24K   64 downloads
Promotive Diff. Thanks to Phil and his team for sending all the way here. Ratio is 3.1.
Attached File  003.JPG   31.65K   54 downloads
This is a planetary gearbox made by Roadster cycle. We had new custom shafts made as we are tight for space (One of the UK ones would have been better in hindsight but had this one in my garage collecting dust.
Attached File  004.JPG   34.74K   35 downloads
Attached File  006.JPG   35.2K   22 downloads
Chris
Edited by proutyc, 02 May 2016 - 03:05 AM.
#2 proutyc
proutyc
  • 16 posts
Posted 03 May 2016 - 10:20 AM
Was a little bored tonight and really want to make sure we could fit the hayabusa into the front subframe.
The good news is yes it does, just.......
We appear to have about 10mm clearance at most places. The turbo plumbing is going to be a challenge.
Attached File  IMG_1657.JPG   118.7K   60 downloads
Attached File  IMG_1656.JPG   128K   65 downloads
Attached File  IMG_1655.JPG   115.4K   37 downloads
#3 proutyc
proutyc
  • 16 posts
Posted 19 May 2016 - 07:54 PM
I've managed to get in the garage a bit the last few nights so progress is coming along.
Man everything is tight
Attached File  001.JPG   73.29K   60 downloads
#4 jackuig
jackuig
  • 39 posts
Posted 19 May 2016 - 08:11 PM
Awesome little project you've got there, Chris!
Car looks really smart as well! What arches is it you have on your clubman?
#5 dundahead
dundahead
    Starting My Mini Up
  • 1 posts
Posted 23 May 2016 - 11:45 AM
what wouls the 0-60mph on this project be? and 0-200km/h
#6 proutyc
proutyc
  • 16 posts
Posted 23 May 2016 - 11:08 PM
Thanks for the question. Not to sure at the moment as traction will take some work from 0.
I will be experimenting with traction control as used by ecu editor.
That said it should be very rapid as I'd expect it to weight 50-70kg less than a A series and have over 200hp at the wheels at 5psi
#7 proutyc
proutyc
  • 16 posts
Posted 30 May 2016 - 08:36 PM
Its starting to get a bit cold in the garage but managing to keep a few things ticking along. Just fabricating the exhaust header now then the subframe will come out for paint. That part is almost finished now, then its the tough part of wiring and certification
Attached File  002.JPG   45.56K   39 downloads
Attached File  003.JPG   72.07K   58 downloads
Attached File  002.JPG   80.71K   48 downloads
#8 proutyc
proutyc
  • 16 posts
Posted 02 June 2016 - 07:41 PM
Making a little more progress. We really had no option other than turbo as you can see from the exhaust. This only clears the firewall by about 15mm.
Exhaust is going off to HPC for coating anf then its onto the turbo water cooled plenum.
  • Attached File  001.JPG   67.89K   48 downloads
  • Attached File  002.JPG   78.09K   50 downloads
#9 Squares
Squares
  • 34 posts
Posted 05 June 2016 - 11:14 PM
That is looking great. Good luck and keep going.
#10 proutyc
proutyc
  • 16 posts
Posted 07 June 2016 - 10:10 AM
Many thanks for the comments.
Got the exhaust welded fully and turbo mounted.
The engine back in the car as pictured, it fits but it's all right. Exhaust clears by 25mm, engine clears the bonnet by 10mm and the diff misses engine by 5mm
#11 proutyc
proutyc
  • 16 posts
Posted 08 June 2016 - 05:29 AM
And the engines in
#12 proutyc
proutyc
  • 16 posts
Posted 16 June 2016 - 11:16 PM
Still ticking along.
Almost at the end of the main fabrication parts.
the exhaust is currently away getting ceramic coated as I'm concerned with under bonnet temps.
I'm starting the plan the electrics swap over. The car will have all but the electric water pump, wipers, heater and demister running through the Suzuki ecu. This means a large amount of the existing mini wiring has got to come out.
New fuel lines are currently being run. 5/16 from tank to engine bay and a 3/8 return line.
Attached File  001.JPG   50.95K   34 downloads
You can see the full length custom radiator, This is 600mm long and 190mm deep (Approx). It is also dual core so should provide twice the volume of the standard hayabusa rad
Attached File  002.JPG   28.17K   23 downloads
Edited by proutyc, 16 June 2016 - 11:18 PM.
#13 proutyc
proutyc
  • 16 posts
Posted 24 June 2016 - 01:40 AM
Been waiting for the exhaust to come back but have managed to do some house keeping while we wait. Everything fits Ok
Attached File  002.JPG   36.86K   37 downloads
#14 Squares
Squares
  • 34 posts
Posted 24 June 2016 - 08:31 AM
This is looking excellent. What a great build, that subframe fabrication work is superb.
Keep going.
#15 steveo
steveo
  • 151 posts
  • Local Club: looking
Posted 08 August 2016 - 11:15 AM
200bhp @ wheels will be more then fun to get off the lights! With addition to the extra torque the turbo bike engine offers over NA
