Any suggestions are welcome to help me solve this:
After pulling the wiper motor and spiral/toothed cable in order to replace a corroded wiper wheelbox, I lost running-lights/side-lights/dash-lights and dim-dip/low-beams. (unrelated systems I know, but it was the ONLY thing I was working on before losing the lights!)
I run a LHD 1991 Mainstream carb'd Mini Cooper in NYC. Had it about 3.5 years. I have no additional driving lights in place, just the stock headlight housing that has the integrated side-light and the big, round two filament bulb. I believe I have the "Pink dim-dip" relay, although I have never seen it, but I also believe the PO had removed the resistor by the radiator because A) I don't see the resistor, just the socket and B) the low-intensity filament does not light when I turn on the ignition with just the running/side-lights switched on (that is when they used to work :-( ).
First thing to rule out is the main lighting switch:
Approximately 6 months ago I cleaned up the interior of the main lights rocker switch because some melted plastic was preventing the dim-dip/low-beams from illuminating (I'd get sidelights only), but I am confident that it is in proper working order still because I have tested it both with a continuity tester and I have also "flipped it over" in order to plug in JUST the Brown HOT wire lead, exposing the other two pins to test, I looked for 12+Volts to appear on the Red and Blue pins and it performs properly: in position 1 neither Red, nor Blue have power; in position 2 Red goes 12V; and in position 3 Blue AND Red go 12V.
(no need to suggest adding relays, from what I've read on these forums for the past several hours, I've learned that I should definitely be fitting relays on my headlights to prevent further switch melting in future, but for just right now I simply need to get basic headlights back working before this weekend)
Next the fuse box:
First I checked each and every fuse in the fuse box along with the inline fuses behind the carb via continuity tester - all good, none blown.
Then I looked for voltage for the running/side-lights: I do not get 12V on the fuse box at pin 7 (Red side) when the main switch is in positions 2 or 3 so I feel that the problem must be between the leads from the switch in the cabin on their way to the fuse box. And this is just running//side light operation - I'm not even talking about dim-dip/low-beams yet (presumably managed by the Pink Relay) - if the red lead from the main switch is not granting power to the Pink dip-dim relay - could that cause no headlights?
Further testing tells me the running/side-lights loom (after the fuse box) seems OK:
I jumpered my Brown HOT on the fuse box (via an in-line fuse jumper/tester that I fabricated) to fuse box pin pin 8 (the Red/Green side) and the running/slide lights all came on - I get the same results if I feed 12V to the pin 7 (Red side) as long as the fuse is in place, so I believe that the major portion of the loom is OK and the grounds exiting the various running/slide light lamps are sound.
Now the odd stuff you need to know:
About a year ago some rats chewed through a Blue/RED wire on the engine compartment side of the firewall and I lost dim-dip/low-beams. Note that I soldered in a new wire segment in and have had dip-dim/low-beams FINE for all this time. Since this ONLY affected headlights, NOT sidelights too, I discount this as causative this time.
A year before that, I took the Mini to a PepBoys for the annual inspection and they couldn't get the blinkers/directionals/turn-signals to light - I popped the fuse in the box and reseated it and got those back, but I noticed my dash lights and right rear tail light (not brake light) were not illuminated. As a quick fix to drive home I jumpered from the left taillight over to the right and that then illuminated (as did the dash lights). After several repeat events of blinker-loss (which I discovered was also brake-lights-loss and reverse-lights-loss too), I removed the entire fuse box and cleaned it up, testing the fuse box tabs for conductivity because I understand the rivets sometimes fail to conduct from the fuse to the tabs, What I found was corrosion inside the White and Green wires of fuse 2-3 and fixed that - NO issues with blinkers/brakes/reverse-lights since (although I still have that jumper in the boot that was illuminating the dash lights in place).
One other thing that might tie into this problem "timing-wise":
Recently - perhaps coincidentally, I noticed that my high-beam stalk control was no longer locking in the "pushed-away" position. It still would flash when "pulled" and also flashes when pushed now, but it just won't lock "on". Could this be part of my problem? I thought this switch only powered up the high-beams ALONG with the dip-dim/low-beams - am I mistaken - does the stalk in some way "toggle" between the different headlights: pushed=high/centered=low/pulled=flash/high?
And now the super weird bit:
When I gave up trying to track the running/side-lights/dash-lights & dip-dim/low-beam problem down scientifically, I fell back on the "Well, what did you disturb while messing with the wiper repair?" tactic. Over by the motor there was a loom that is moved around a bit, but the loom tape was intact upon inspection and it wasn't really disturbed too much. But over on the left-hand-side where the one corroded wiper wheel box was, I was really moving the foam on the bulkhead down and around a bit to get my hand and a wrench in there. I noticed a rectangular flasher 9FL12V relay nestled in a cutout in the foam there and on a lark I just pushed it down thinking maybe I dislodged it and need to seat it again. VOILA! My running/side lights AND my dip-dim/low-beams miraculously began to work. I couldn't see how a flasher unit would play a part in the main lights circuit, but as it was getting dark and raining by then so I simply I counted myself lucky and headed in for the night.
The following morning my luck had run out as neither my running/side lights nor dip-dim/low-beams worked anymore. Plus, when I pulled that relay out of the foam to get a better look, I found its Purple/Orange terminal had experienced a meltdown. Based on the condition and lack of any smell, it must have happened some long time ago - see pics (note the black thing under the relay is a car alarm horn that has been in place for 3 years - not a likely culprit here)
It's a wonder that my flashers have been working like a champ. It's possible that I temporarily grounded the P/O lead, but I do not see how grounding that circuit would contribute to the running/side-lights or dip-dim/low-beams circuit spring back to life. I also found it strange that the "out" wire was Green/White instead of Green/Pink stripe like the wiring diagrams call for.
See attached all the wiring diagrams I've been pouring over trying to suss this out - note the "relay" diagram is MY guess at what is going on inside that Pink relay...it could be completely wrong!
I'm pretty much at wit's end here as I'm not sure what to check/test next...
Thanks in advance to anyone who can offer help/suggestions/prayers!
Jim
Edited by [email protected], 04 May 2016 - 02:43 AM.
