I had this it was the exhaust box hitting the seatbelt bolts that go through the floor,worth a look although may not be what is causing your noise
Maybe the gear selector body is moving due to worn bushes? Does the exhaust run close to anything?
I might take it out and give it a clean as is dirty.
Can you point me to the bushes i need ?
2 cotton reel type rubber mounts that have 1/2 inch nuts up through the floorpan. More likely exhaust though
Removed the seatbelt bolts and the carpets to have a clear view of the gear selector while driving.
Also the exhaust only touches the corner of the lower bracket on the engine, but is tight, so much that has a dent. I will try to move it.
The noise is still there and can't see any movement in the the gear selector when it happens.
Is more like and impact rather then a knock knock, feels like the whole car moves when decelerating.
