Knocking Noise When Decelerating...
12 replies to this topic
#1 007xico
007xico
  • 65 posts
Posted 06 May 2016 - 04:14 PM
Hi,
when decelerating there is a loud knocking around the gear selector.
So far changed  the solid front subframe mounts, top engine steady with new bushes and fitted a lower engine steady.
If i try moving the engine by hand, won't move at all.
Any ideas would be welcome because i can't figure it out.
1989 998cc Mayfair
#2 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 06 May 2016 - 04:20 PM
Maybe the gear selector body is moving due to worn bushes? Does the exhaust run close to anything?
#3 007xico
007xico
  • 65 posts
Posted 06 May 2016 - 07:47 PM
I might take it out and give it a clean as is dirty.
Can you point me to the bushes i need ?
#4 Wiggywithahailo
Wiggywithahailo
  • 505 posts
Posted 06 May 2016 - 09:17 PM
I had this it was the exhaust box hitting the seatbelt bolts that go through the floor,worth a look although may not be what is causing your noise
#5 ChopperHarris
ChopperHarris
  • 1,139 posts
Posted 06 May 2016 - 10:25 PM
2 cotton reel type rubber mounts that have 1/2 inch nuts up through the floorpan. More likely exhaust though
#6 007xico
007xico
  • 65 posts
Posted 07 May 2016 - 11:24 AM
Removed the seatbelt bolts and the carpets to have a clear view of the gear selector while driving.
Also the exhaust only touches the corner of the lower bracket on the engine, but is tight, so much that has a dent.  I will try to move it.
The noise is still there and can't see any movement in the the gear selector when it happens.
Is more like and impact rather then a knock knock, feels like the whole car moves when decelerating.
#7 ChopperHarris
ChopperHarris
  • 1,139 posts
Posted 07 May 2016 - 12:53 PM
Can you reproduce the noise stationary while putting the car in reverse and letting the clutch partly up (handbrake on)?
Look at the engine/subtrame mounts while someone does this for you. Also if you reproduce the knock its easier to locate with a few mates round to pinpoint it
#8 AlexMozza
AlexMozza
  • 1,248 posts
  • Local Club: Not Yet
Posted 07 May 2016 - 02:31 PM
Top engine steady is a favorite.
Grap the top of the block and see if you can rock it forwards and back.
#9 ChopperHarris
ChopperHarris
  • 1,139 posts
Posted 07 May 2016 - 02:59 PM
Alex, OP says
#10 Coxie
Coxie
  • 461 posts
Posted 07 May 2016 - 04:04 PM
Might not be the full problem but mine was running a little rich and on deceleration especially down hills with foot off the throttle it would lurch and you could hear the engine steady pulling against the crossmember.
when you say it feels like the whole car moves when decellerating, this is exactly what I was experiencing.
It made all the clunks and thumps go away once the mixture was right and the car was decellerating smoothly.
Just a thought.
#11 Xinarin13
Xinarin13
  • 81 posts
Posted 26 January 2018 - 02:01 PM
Was there ever a solution to this? I fear there may be something wrong with my new purchase and I am trying to figure it out... this sounds very similar to what I am experiencing.
#12 nicklouse
  • 18,999 posts
Posted 26 January 2018 - 02:03 PM
there are many things that it could be, work you way through them.
#13 Xinarin13
Xinarin13
  • 81 posts
Posted 26 January 2018 - 02:05 PM
True, I am just trying to figure out the best place to start. I have some symptoms and I am seeing what matches and doesn't... Was reading through this one and was just curious if he ever figured it out.
