What Attaches To Slave Cylinder Bracket
6 replies to this topic
#1 Pairaminis
Pairaminis
  • 194 posts
Posted 06 May 2016 - 10:37 PM
Can someone please tell me what attaches to the two small holes at the top of the clutch slave cylinder bracket on the clutch cover of a 998 A+ motor.  I know what the four large holes are for. (see photo)
Jack
#2 blackbelt1990
blackbelt1990
  • 2,625 posts
  • Local Club: Minimus Maximus
Posted 06 May 2016 - 10:41 PM
I think my battery cable runs through a grommit in there. Nothing in the small holes though.
#3 Wrgreen
Wrgreen
  • 27 posts
Posted 07 May 2016 - 11:01 AM
Yes battery cable
#4 Ethel
  • 26,580 posts
Posted 07 May 2016 - 11:15 AM
Was it where the Metty clutch damper lived? So long since I've seen one I can't remember for sure
apparently so http://www.ebay.co.uk/itm/322096669880
#5 blackbelt1990
blackbelt1990
  • 2,625 posts
Posted 07 May 2016 - 03:59 PM
What does the damper do? I had one on a van and I took it off. I had no idea what it was but it wouldn't stop leaking fluid!
#6 tiger99
tiger99
  • 8,584 posts
Posted 07 May 2016 - 04:20 PM
The damper limits the rate of engagement and disengagement of the clutch to discourage a potentially damaging and always unpleasant effect when the driver's foot, muscles and nervous system are involved in an unstable feedback loop comprising also the clutch, engine torque, movement of car etc. It can be so bad that only a very highly skilled driver can make a smooth start without umpteen cycles of grab and release. Those with aircraft experience will have heard of "pilot induced iscillation", another variant of much the same thing. We can't change the response time, and in particular, phase lag of the human in the loop, so it has to be done elsewhere, in this case by the damper. It also is one of several reasons why some mediocre cars have steering dampers, which are also used to try to mask the effects of kickback caused by inept designed suspension geometry etc. The Mini only benefits from a clutch damper if the engine steadies are in poor condition or a particularly fierce racing clutch is fitted. The fierce cluth effectively gives greater gain around the loop, in terms of acceleration of car per mm of driver's leg movement. The Metro, being an altogether softer car has different time constants in the engine mounts and with a normal human in control needs one. You would probably need to read up on non-linear multi - variable control theory to get the full picture...
#7 Ethel
  • 26,580 posts
Posted 07 May 2016 - 07:22 PM
I don't remember them on Verto clutches, but they obviously were. It was an attempt to civilise the Metro and give it wider market appeal by making the clutch engagement softer.
