just after some opinions if this is acceptable/good practice.
basically re-building the carb and wanted to add a fuel filter. due to the filter i bought being quite large and the new pipe being quite stiff i've run a big loop of pipe up past the servo bracket and then back towards the carb. basically its an attempt to position the filter away from the exhaust and not in the way of the fuse-box and clutch reservoir. i also thought it would be good to have a down hill run from the filter to carb.
is it safe ? is it too much ?? should i get a smaller filter ???
opinions please
