Mushroomed Drive Shaft
13 replies to this topic
#1 WimpyMiniMan
WimpyMiniMan
  • 149 posts
Posted 07 May 2016 - 05:32 PM
Hi there, I accidentally mushroomed my drive shaft while hitting it out of the hub, and now the hub nut won't go on - any ideas?
Kind Regards
George
#2 nicklouse
  • 18,605 posts
Posted 07 May 2016 - 05:34 PM
New CV then.
#3 RedRuby
RedRuby
  • 1,201 posts
  • Local Club: No
Posted 07 May 2016 - 06:05 PM
As above or if it is only slight and at the tip of the thread you could try gently filing the damage out.
#4 Batmini
Batmini
  • 378 posts
Posted 07 May 2016 - 06:07 PM
How much is damaged? If just on the end, you may be able to file the very end of it. So long as there's still thread visible after winding on the castle nut then it should be ok.
Redruby beat me to it!
Edited by Batmini, 07 May 2016 - 06:08 PM.
#5 AlexMozza
AlexMozza
  • 1,248 posts
  • Local Club: Not Yet
Posted 07 May 2016 - 06:50 PM
Try a thread file first.
#6 Magneto
Magneto
  • 889 posts
  • Local Club: KC MINI Club
Posted 07 May 2016 - 06:52 PM
Next time, if you use a brass drift it will keep this from happening, the bras is softer than the steel but still strong enough to bash the shaft out of the hub.
#7 WimpyMiniMan
WimpyMiniMan
  • 149 posts
Posted 07 May 2016 - 07:29 PM
It's only a little at the end still would be some thread on the other side of the locking pin hole.
#8 MRA
MRA
  • 7,607 posts
Posted 08 May 2016 - 12:48 AM
Your statement above tells me you need to throw it away, the end to the "pin" hole is a fair way, if mushrooming has gone this far then the rest of the threaded section will have damage, most likely it will be tapered, not something a thread file will fix.
But I guess anything can be bodged...
#9 WimpyMiniMan
WimpyMiniMan
  • 149 posts
Posted 08 May 2016 - 07:40 AM
I managed to file it and this is how it looks now - any thoughts? Goes on and off fine.
Regards
George
#10 WimpyMiniMan
WimpyMiniMan
  • 149 posts
Posted 08 May 2016 - 07:42 AM
Here's the pic
#11 MRA
MRA
  • 7,607 posts
Posted 08 May 2016 - 12:30 PM
It looks like you have enough thread, good luck, hope it all works well for you.  Just keep your eye on it over the next few hundred miles to be on the safe side.  Although if it came loose you should feel it in the way it drives.
#12 Batmini
Batmini
  • 378 posts
Posted 08 May 2016 - 02:57 PM
Looks fine, plenty of thread
#13 Magneto
Magneto
  • 889 posts
Posted 08 May 2016 - 05:56 PM
Tighten it properly and put a new cotter pin in it, should be fine.
#14 WimpyMiniMan
WimpyMiniMan
  • 149 posts
Posted 10 May 2016 - 04:49 PM
Tightened and put the pin in - tested the car down our lane and it seems good going for a short test drive on a flat wide road in a bit ;)
