Turbo Stuff + Other Stuff!
No replies to this topic
#1 morley
morley
  • 903 posts
Posted 10 May 2016 - 05:34 PM
Hi guys, having a bit of a clear out to make some room...
fuel pressure regulator, bracket included £35 posted
turbo fuel pump, £35 posted
oil return outlet and hoses, £15 posted
gt17 turbo actuator bracket, £10 posted
captive engine mounts, new, £6 posted
thermostart housing with take off, £10 posted
gt17 turbo, lots of play, in need of a rebuild, £70 posted
turbo inlet manifold, £35 posted
Rebuilt turbo carb and abutment plate, not used since rebuild, £140 posted
gt17 turbo, very minimal play, exhaust housing has been modified for use on metro turbo manifold, and actuator mount cut off but will be included, £100 posted
omega 1275 +20 10cc dish cast pistons, brand new in box, £295 posted
playmini back box 2" inlet to 3£ outlet - £40 posted
7.5 gallon fuel tank, £20 collected
Custom alloy fuel tank approx 35 litres
620mm long
Height 140mm
Width 400mm
8mm outlet, push on type
8mm breather, push on type
8mm splash bowl overflow pipe, push on type
10mm return, push on type
Alloy screw cap + splash bowl
Alloy mounting brackets
Fittied with a fuel tank sender + flange [VDO]
Foam filled
Sump
Brand new, only used for mocking up, just dusty from storage, £220 posted
Thanks!
James
Edited by morley, 16 May 2016 - 08:30 PM.
