Time To Change The Ptc?
4 replies to this topic
#1 96minimig
96minimig
  • 169 posts
Posted 10 May 2016 - 08:25 PM
Hello found that recently my spi mini developed a slight splutter when warming up from cold.
I have run my Sykes Pickavent tool and actuator tests out OK for everything inc ptc manifold heater.
As the same while running coolant temp is fine no errors found. No air leaks vac hoses are fine
The car starts fine and runs fine just while cold or warming up in the early stages from cold it slightly spluttery and trying to drive it like this I experience a slight hesitance in acceleration or running. Then it just suddenly clears and then it's running with no problems whatsoever.
Was thinking maybe the ptc heater isn't working or not working effectively.
Can anyone shed light on this? Also noticed they are not available in many places and are quite expensive.
#2 FlyingScot
FlyingScot
  • 2,664 posts
Posted 11 May 2016 - 08:19 AM
The test for the PTC is just the relay, (which you can hear) check the wire isn't hanging off underneath.....
Could be a number of things to be honest but worth checking the PTC
FS
#3 Fast Ivan
Fast Ivan
  • 2,909 posts
Posted 11 May 2016 - 09:27 PM
May not be related to that side of things and could be down to just needing a good service, including checking the valve clearance
#4 96minimig
96minimig
  • 169 posts
Posted 14 May 2016 - 01:26 PM
It's had a service a valve clearances are fine.
Tested the wire to the relay box using actuator test on my SP tool from the ptc and I have power when the tool activates it.
The hesitation is only slight and only when cold ish from starting
#5 dbcool20
dbcool20
  • 91 posts
Posted 16 May 2016 - 03:49 PM
Had some issues with mine as well. checked that I had 12v on the connector and all was fine. I  then decided to go ahead and remove the PTC to check it. quickly figured out it was dead, when i shook it in my hand it made a rattling noise as if it was filled with sand and stones. popped it open and the resistance was completely fried and in thousands of little bits and pieces. minispares and somerford mini have them in stock part number is MED10003 but yes indeed for what it is they are bloody expensive.
