Applying Dynax
6 replies to this topic
#1 deanymini
deanymini
  • 771 posts
Posted 11 May 2016 - 08:16 PM
What would be best:
Apply Dynax straight to bare metal or apply to painted metal?
Also, which Dynax should I get? It's for the underside. Is S50 the one to get for this?
Opinions gratefully received!
#2 Daz1968
Daz1968
  • 2,058 posts
Posted 11 May 2016 - 08:28 PM
I would always apply epoxy primer, stonechip and top coat gloss first then only put dynax s50 where needed, mainly inside sills and cavities. Dynax ub appears to be better for general coating underside
Edited by Daz1968, 11 May 2016 - 08:31 PM.
#3 Richie83
Richie83
  • 1,495 posts
Posted 11 May 2016 - 09:15 PM
Exactly as above. S50 for the sills, inside doors, and box sections etc. I chose to use UB on the underside too.
Edited by Richie83, 11 May 2016 - 09:15 PM.
#4 spiguy
spiguy
  • 1,537 posts
Posted 11 May 2016 - 10:20 PM
I've gone for S50 in cavities, and UC underneath - all wheel arches, under wings, outside of sills, boot floor etc. The clear stuff is good as you can get it on there really quite clear, so you can still actually see everything underneath. Ideal for detecting anything starting to show signs of rust. The UC has pretty decent mechanical resistance too, I actually wash underneath regularly with a soapy rag then rinse off. UC stays put. It's so much better than waxoyl.
#5 dyshipfakta
dyshipfakta
  • 1,696 posts
Posted 11 May 2016 - 10:33 PM
You definatly need to paint any and all metal you can with something atleast. I like por15 then epoxy primer then gravitex then top coat then waxoyl type stuff. Seems excessive now I write it. Hopefully my sills won't rot in a hurry though !
#6 spiguy
spiguy
  • 1,537 posts
Posted 11 May 2016 - 11:33 PM
I've had dynax UC on a vent blanking plate that I just painted with Acid etch, nothing else, for about a year and a half. You can barely tell it's there as it is see through, and no rust whatsoever has formed on the plate. Definitely paint before wax though, I did this purely as an experiment to see how the stuff would perform (dynax UC). I have been impressed - it is really good stuff!
#7 deanymini
deanymini
  • 771 posts
Posted 12 May 2016 - 01:27 PM
Thanks for the feedback here guys. Very useful. I think I'll go to town on the 'belly' in the summer and get it bang on.
