Bump Starts But Nothing On The Key ?
10 replies to this topic
#1 Wiggywithahailo
Wiggywithahailo
  • 505 posts
Posted 14 May 2016 - 12:43 PM
Hi all car was fine yesterday but today it won't start it will bump start however
Could it be the solonoid
Car is a '91 mini 1000
Thanks for any advice
Mark
#2 Steve220
Steve220
  • 5,067 posts
  • Local Club: BMC
Posted 14 May 2016 - 02:09 PM
When you turn the key to ignition 2, do you hear any relay clicking at all? Have you checked all fuses?
#3 Wiggywithahailo
Wiggywithahailo
  • 505 posts
Posted 14 May 2016 - 02:29 PM
Hi Steve
no there's nothing
I have just tested the starter and solonoid they are fine
Battery is fine too as are fuses
Totally stumped
#4 62S
62S
  • 1,243 posts
  • Local Club: You must be joking!
Posted 14 May 2016 - 03:11 PM
Could be a broken or non-earthing earth strap?
#5 Wiggywithahailo
Wiggywithahailo
  • 505 posts
Posted 14 May 2016 - 03:14 PM
Earth strap is new. ?
#6 Cooperman
  • 23,326 posts
Posted 14 May 2016 - 03:39 PM
It sounds like the ignition switch part of the lock assembly has failed. Not unusual. Check for a 12v signal from the switch when the key is moved to the 'start' position. If no output a new ignition switch assembly is needed, or replace with a push-button start which is easy, cheap and you get to keep the original ignition key.
#7 Wiggywithahailo
Wiggywithahailo
  • 505 posts
Posted 14 May 2016 - 04:02 PM
Thanks cooperman
I hope it is as been stressing all afternoon
So to clarify this is a switch located at he ignition barrel?
#8 Steve220
Steve220
  • 5,067 posts
  • Local Club: BMC
Posted 14 May 2016 - 04:21 PM
Yeh, thats the one. Do you have a multimeter?
#9 Cooperman
  • 23,326 posts
Posted 14 May 2016 - 04:29 PM
If it is the switch, which as Steve says you need a multi-meter to check, you can simply fit a push button. Run a lead from the ignition 'on' circuit to the new button and connect the 'start' lead from the ignition switch to the other side of the new button and it will all be fine again. A very simple and very low-cost mod which, some say, is better than the switch and certainly more reliable.
#10 Wiggywithahailo
Wiggywithahailo
  • 505 posts
Yes but it's overly complicated for someone who has limited knowledge of how to use it,and I have now run out of time for today and working tomorrow
But thanks guys I reckon my problem will b solved
#11 Wiggywithahailo
Wiggywithahailo
  • 505 posts
Posted 16 May 2016 - 08:19 PM
So turns out it was the starter relay and now has an mot
Thanks for everyone's help
See u in Brighton
Say hi
