Blocked Off Air Vents
5 replies to this topic
#1 grahama
grahama
  • 2,442 posts
Posted 17 May 2016 - 06:33 PM
Hi all,
I have blocked off the fresh air vents as I have Windows lol. However the hose to heater is still present from under wing as usual.
Has anyone just blocked off the inlet hose under the wing so it doesn't just blow through and not go into the heater??
Hope that makes sense!!
Graham
#2 THE ANORAK
THE ANORAK
  • 3,946 posts
Posted 17 May 2016 - 08:24 PM
i took off the pipe under the dash rail. it runs near the pedals from the inner wing to the heater. if you take this off you just have a round outlet to block. i used the plastic lid from a pot of screws. it fitted in perfectly and i sealed it in place.
now the heater takes its air from in the cabin instead of being boost fed with cold air from out side.
#3 Batmini
Batmini
  • 378 posts
Posted 17 May 2016 - 08:27 PM
Mines the same, but more because i couldn't be arsed fighting it back on again!
#4 grahama
grahama
  • 2,442 posts
Posted 17 May 2016 - 09:15 PM
With no fresh air how do you find the windscreen us for fogging up??
#5 THE ANORAK
THE ANORAK
  • 3,946 posts
Posted 17 May 2016 - 09:27 PM
Naff... open the window half inch and its ok.
#6 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 18 May 2016 - 11:42 AM
We have welded both fresh air vents up and the cold air feed for the heater... If you need air drive with the window cracked open
