Strong Smell Of Petrol
8 replies to this topic
#1 Wiggywithahailo
Wiggywithahailo
  • 505 posts
Posted 18 May 2016 - 12:59 PM
Hi all
I have strong petrol smell but only after a run
No visible leaks and carb was rebuilt last year also no smell inside the car whilst in use the car runs fine and has just been motd
'91 mini 1000 no mods
#2 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 18 May 2016 - 01:03 PM
Obviously check the system from start to finish for leaks. Check that the fuel tank vent pipe (from top of tank to floor) hasn't split as they like to do that and has the one way valve fitted.
It's not running rich is it?
Not leaking out of overflow pipe?
#3 littlemissmagic
littlemissmagic
  • 514 posts
Posted 18 May 2016 - 01:16 PM
I have exactly the same symptoms with my mini at the moment and pretty sure it's because it's too rich.
I can only smell it when I open the window and after a bit of a run.
Edit: I had my carb rebuilt last month and it's since then I have started to smell it but that could be because I never had the window open much in winter!
Edited by littlemissmagic, 18 May 2016 - 01:17 PM.
#4 Wiggywithahailo
Wiggywithahailo
  • 505 posts
Posted 18 May 2016 - 01:18 PM
Just been mots so mixture is ok new vent pipe on tank as car was totally restored just over a year ago
Also doesn't do it all the time?
Edited by Wiggywithahailo, 18 May 2016 - 01:18 PM.
#5 pothole
pothole
  • 317 posts
Posted 18 May 2016 - 01:27 PM
I also had a strong petrol smell in my 1995 Sidewalk, I checked everything pipes gaskets but still the smell and I could not see any leaks. In the end I changed the tank over for another one. When I removed the tank half way up the side which would have been under the filler hole and down to the bottom the paint had all flaked off, so something was leaking, I found what can only be described as a centre punch but not a hole I cleaned off the paint, removed the pump and filled the tank with water to the brim of the pump hole, checked it an hour later still full. Next day I checked it still looked full but from where the centre punch mark was to the botom of the tank was a streak of rust as the water had been seeping through the punch mark. I would have been searching for a month of sundays and would never had found that leak.
#6 Wiggywithahailo
Wiggywithahailo
  • 505 posts
Posted 18 May 2016 - 01:31 PM
I do wonder about the tank but I refurbished it on the rebuild
New sender unit new sealer inside
??? I will have another sniff
I think it's engine bay end myself but can't b sure
#7 pothole
pothole
  • 317 posts
Posted 18 May 2016 - 02:05 PM
Heres a couple of photos to show you what I mean there is no obvious leak, but you can see the route it was taking.
Attached File  hol2.JPG   49.12K   11 downloadsAttached File  hole.JPG   67.17K   9 downloads
#8 Wiggywithahailo
Wiggywithahailo
  • 505 posts
Posted 18 May 2016 - 02:13 PM
I will have to investigate further Saturday morning
#9 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 18 May 2016 - 02:28 PM
Just because the mixture is ok at idle, doesn't necessarily mean it won't be really rich at the top end. But it does sound like your problem lies elsewhere.
