Hi Guys,
me again...
Trying to get my project running so i thought i'd establish spark as its the only thing missing.
I have a
65dm4 electronic dizzy & lucas sports coil.
I've wired the coil 12V to + and - to earth
I've wired the distributor black white to earth via the coil & the white to the 12V on the coil
the 65DM4 has a new cap, rotor arm, spark plugs & leads.
Stuck the timing light on and nothing.
Stuck the spark plug against the earth (threaded body to visually check for spark) and still nothing.
The coils getting hot so safe to assume its working.
First off, does anything sound amiss? have i made a silly mistake somewhere?
Ive taken the dizzy cap off and visually seen the rotor arm spinning around and you can see in the centre where the coil connection has been made.
If i've not done something obvious then is there a way of checking the module on the side of the dizzy? Its been sat a little while but was working when it came off the last mini.
thanks guys,
Chris
