Supercharger Camshaft Options.
10 replies to this topic
#1 Daveb1275
Daveb1275
    Starting My Mini Up
  • Validating
  • 4 posts
Posted 21 May 2016 - 10:47 AM
Morning all, I'm currently building a 1275 engine that will be supercharged using the eaton m45, it will be going in my 1275gt clubman.
Some advice on cams would be much appreciated. I have a couple available, standard 1275, spi, and a piper bp285.
Any thoughts / advice greatly appreciated.
Cheers, Dave.
#2 mini13
mini13
  • 3,811 posts
Posted 21 May 2016 - 10:58 AM
Pretty sure the SPI and 1275 are the same profile, will work ok for a charger but a bit more edge wouldnt hurt. The 285 will be pretty lairy in a charged engine, basically its a full race came for a super charged engine.
I would sugest somthing like a 266, or SW5, the kent 274i would be really good as its on a wide LCA.
#3 Steve220
Steve220
  • 5,058 posts
  • Local Club: BMC
Posted 21 May 2016 - 12:02 PM
If you can get hold of one, the MG metro cam works great with a charger.
#4 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 21 May 2016 - 01:19 PM
Ive got a sw5 on mine and people say its good for a charged engine, but I don't rate it really. Its a great cam for na. I would have a look on the Podifold boost pressure calculator and go for one that reduces the boost pressure in the manifold. A cam that reduces manifold pressure means its getting better flow into the engine.
#5 Ethel
  • 25,991 posts
Posted 21 May 2016 - 01:35 PM
A belt driven charger shouldn't be any different to a N/A engine as far as cam choice goes. You can make your power at lower rpm though, so less need to go for anything as lairy.
#6 mini13
mini13
  • 3,811 posts
Posted 21 May 2016 - 06:24 PM
I'm going to disagree slightly, although they will work, longer cams with a lot of overlap  really hurt MPG on supercharged engine.
#7 Daveb1275
Daveb1275
    Starting My Mini Up
  • Validating
  • 4 posts
Posted 21 May 2016 - 08:24 PM
Well you've all given me something to ponder on. I think I'll steer clear of the BP285 on your recommendations.
Hubba, what would be your choice of cam, it seems your not too keen on the SW5.
Cheers.
#8 Ethel
  • 25,991 posts
Posted 21 May 2016 - 10:09 PM
That makes sense. While it might not cost you any power, as it would with a turbo's back pressure, you could get the opposite blowing  straight through to the exhaust. Not only wasted fuel, but bad emissions if you want to drive on the road.
#9 mini13
mini13
  • 3,811 posts
Posted 22 May 2016 - 09:39 AM
yep, Stu at Vmax is the person to talk at really, I know he's build engines with 286's and got some wide LCA cams done.
#10 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 23 May 2016 - 02:41 PM
Cheers.
I'd go for something like the Calver RE13 or Avonbar PH2 Turbo cam.
I definitely think there is a difference between NA and FI cams. My sw5 was superb naturally aspirated and took off at 2500rpm and I don't think it is any coincidence as in forced induction it bogged down in exactly the same rev range. (don't think the long inlet on the suck through helped).
I have spent may hrs and £'s working round the issue.
#11 Gr4h4m
Gr4h4m
  • 1,802 posts
  • Local Club: Club less.....
Posted 24 May 2016 - 07:25 AM
Look for something with a wide LCA of about 112. Vamp seel some supercharged specific cams, or the 274i or the Graham rustle re13t which you can get as a 112lca should work off of the shelf.
