Vibrating Brake Pedal
5 replies to this topic
#1 westlin
westlin
  • 281 posts
Posted 22 May 2016 - 08:37 PM
Since putting the car on the road under heavy braking the brake pedal vibrates/ pulsates. Ive now replaced the discs thinking I had warped discs but still have the same issue. The set up I am running is metro 4 pots, ebc green pads, vented discs, no servo. All bearings were replaced as were ball joints.
im not getting any vibration through the steering.
any suggestions?
#2 nicklouse
  • 18,642 posts
Posted 22 May 2016 - 08:47 PM
The drums?
#3 westlin
westlin
  • 281 posts
Posted 22 May 2016 - 08:52 PM
You think its the drums or you want know what the drums are. If the latter mini fins.
#4 ChopperHarris
ChopperHarris
  • 1,139 posts
Posted 22 May 2016 - 09:22 PM
Oval drums cause the same pulsing as warped discs
#5 westlin
westlin
  • 281 posts
Posted 23 May 2016 - 05:34 AM
Interesting, I know when I was adjusting the rear brakes, when I rotated them it was not always rubbing. Not as easy to check though without a big lathe, Any suggestions on how?
#6 nicklouse
  • 18,642 posts
Posted 23 May 2016 - 08:12 AM
sounds like that is the problem.
