Radius Arms, Need Some Measurements,
Posted 23 May 2016 - 10:45 PM
Reason I was under the impression that the Mini and Metro had the same length arms. I was sure that I measured them the same 30 years ago. But I was not being agreed with the other day.
So I need to remeasure the metro ones I have fitted but I don't have any Mini ones to measure.
So not a direct measurement but along the car length so I can compare.
Thanks in advance.
Posted 24 May 2016 - 12:03 PM
I've got some built arms on the bench at home but I'm not sure what you mean by this?
Posted 24 May 2016 - 12:09 PM
what the radius of the arc they swing about.
Capture.JPG 24K
2 downloads
so the distance between the pin and the axel (center to center) perpendicular to the axel or the shaft.
hope the picture explains.
Posted 24 May 2016 - 02:13 PM
Sure, I should be able to get that measurement for you a bit later.
Posted 24 May 2016 - 04:14 PM
Posted 24 May 2016 - 05:22 PM
30 cm
Which is what I get for the metro as well. Cheers. Now to tell some Germans they were not correct.
Posted 24 May 2016 - 07:07 PM
Posted 24 May 2016 - 09:34 PM
Posted 24 May 2016 - 09:39 PM
