What Tool To Use?
rusty30
, May 25 2016 09:53 PM
7 replies to this topic
Posted 25 May 2016 - 09:53 PM
Probably a daft question, but anyway ..
I need to cut out some smaller bits on my (very slow) resto but not sure how to go about it. I need to cut a samll area out of my top dash rail that has rotted along with the corner of the windscreen suŕround - it's obviously too small an area to get an angle grinder in to - so what do others use?
Posted 25 May 2016 - 09:56 PM
I find a dremmel with the right angle head adapted quite handy for tight areas and small amounts of cutting/grinding
Posted 25 May 2016 - 11:42 PM
Yep I'll second that by a real dremel tool but would also say stick to dremel branded discs there pricey but are stronger than the cheaper equivalent versions
Posted 26 May 2016 - 08:37 AM
Dremel if you have no access to a compressor.
If you have access to a compressor then use a right angle die grinder with a 3mm shanked carbide burr.
Posted 26 May 2016 - 09:14 AM
Drill a hole in it then use a hacksaw blade.
Posted 26 May 2016 - 05:58 PM
I also use a dremmel and the reinforced cutting discs for it are very good in awkward areas, pretty sure you could use a carbide burr in a dremmel as well.
Posted 27 May 2016 - 09:43 PM
I have a black and decker multi tool similar to a dremell. Bought some cheap cutting discs off ebay that hardly scratched the paint!! Reckon if i get genuine dremel discs that should be sufficient?
Edited by rusty30, 27 May 2016 - 09:43 PM.
Posted 31 May 2016 - 09:24 PM
I've used these on 20 gauge. Expensive, but they work.
https://www.amazon.c...ed Clic Mandrel
https://www.amazon.c... Grinding Wheel
