hi
so i have a JDM mini, i understand that it is a hybrid of SPI and MPI
so would i use a SPI code reader pod or MPI code reader pod ??
thanks
Posted 26 May 2016 - 06:13 AM
hi
thanks
Posted 26 May 2016 - 09:18 AM
Posted 26 May 2016 - 05:28 PM
Posted 26 May 2016 - 05:34 PM
Posted 27 May 2016 - 12:37 AM
Posted 28 May 2016 - 08:45 PM
hi recently i found a sykes pickavant acr 4 on ebay and comes with rover pod 1
i have a Japanese 97 mini
what other pods do i need to COMPLETELY tune my car ?
thank you
Posted 31 May 2016 - 08:34 AM
hi guys
another problem came up today !!
so as FS said that i will need a newer version MPI cable to plug into the EOBD plug under the dash on the left side of the steering column, my car is RHD.
but as some say on older mini, there is a white 3 pin plug beside the brake servo ....I HAVE THIS TOOOOOO
so i have a EOBD plug and a white plug on my 1999 JDM ROVER MINI
with using the error code reader, which cable do i need ? and where do i plug it in ?
thanks
Posted 31 May 2016 - 09:54 AM
the 3 pin connector near the brake servo is your mems' diagnostic connection and the obd style port I believe is for the srs system and a different scanner - not to familiar with that part though to be honesthi guys
thanks
Edited by inim_repooc, 31 May 2016 - 09:55 AM.
