I need to buy a crank pulley and dampener for my specialist components 16v engine, I am a litter uncertain ti what I actually need.
The block is a SPI block.
any pointers in the right direction of a decent kit much appreciated.
Posted 27 May 2016 - 10:14 PM
Posted 27 May 2016 - 10:53 PM
Posted 27 May 2016 - 11:08 PM
I would have thought specialist components would supply a crank pulley as it would need a specific design to drive the cam belt.
just crept down to the garage to look at the kit. It looks like there is a pulley for the cam belt but i still need a pulley for the v belt to run the water pump and alternator.
Posted 27 May 2016 - 11:31 PM
The piccy on their website shows a standard V belt water pump pulley, so no reason to expect the crank pulley is any different.
It's still the same crank assembly you're after damping.
MED & KAD have offerings
Posted 28 May 2016 - 12:17 AM
Posted 28 May 2016 - 12:34 AM
Romac are good, but you want to be sure that what ever Damper you choose, it suits your engine. In this regards, I'd suggest talking with a manufacturer of them who doesn't just make them, but understands how they work and what's needed. A wrong selection can end up with a busted crank in short order.
http://www.romac.com.au/balancers.html
Posted 28 May 2016 - 07:36 PM
trouble i have is I donate actually know what the crank pulley and dampener look like. I have never seen one in person.
I think I will go for the Med version. t
Here is the SC cam pelt pulley and the SC instructions outlining a modification of the crank pulley:
And here is a pic i picked up from here: does it have a dampener or just the new SC pulley and standard crank pulley?
Posted 28 May 2016 - 07:59 PM
That bit of tin they tell you to discard is just a crud thrower, come bit to stop the belt getting wedged against the timing cover. The black bit in the other piccy looks like the factory damper after it's been removed to clear those shiny pulleys. I think some of those after-market pulley may be a bigger diameter, maybe get one with a built in trigger wheel?
There a piccies on line of the kad ones with the teeth on either side of the damper.
Posted 28 May 2016 - 08:02 PM
thanks for the help
Posted 28 May 2016 - 08:03 PM
Posted 28 May 2016 - 08:39 PM
You should have one on the old engine.
Already sold. I should have held onto it
Posted 28 May 2016 - 08:42 PM
Already sold. I should have held onto itYou should have one on the old engine.
Posted 29 May 2016 - 09:29 AM
I don't think it will be that hard , since their kit is designed for the standard A+ damper and aftermarket dampers replace that.
Looks like you just need everything to the outside of the belt pulley and an arrangement for mounting the crank sensor that will be clear of your cam drive gubbins. A larger diameter damper or tooth wheel may complicate things if you try to mix 'n match.
Posted 29 May 2016 - 11:03 AM
Posted 29 May 2016 - 11:13 AM
Edited by limby2000, 29 May 2016 - 11:14 AM.
