Welding. Am I About Ready?
10 replies to this topic
#1 Daviewonder
Daviewonder
    Needs an extra inch!!
  • 1,020 posts
Posted 28 May 2016 - 10:08 PM
Hello All
I feel it's time for my procrastinating to end and my restoration project to begin. I've been collecting up the bits I need over the last  few years in between saving for a house and I think I'm about there.
I've made a list of the bits I've got so far. Can anyone see anything that I'm missing that would either be vital or make life a bit easier?
Mig Welder
Argon Mix
Mig Wire
Leather Gloves
Metal Cutters
Gas Regulator
Electric Angle Grinder
Electric Drill
Grinding Discs
Cutting discs
Poly Abrasive Discs
Goggles
Assorted Grips
Spot Weld Drill Bits
Overalls
Steel Toecap Boots
Auto Darkening Welding Helmet
Air Drill
Air Punch and Flange Tool
Air Sabre Saw
Small Air Grinder
200 Litre Compressor
Air Lines
Steel sheets
Trolley Jacks
Axle Stands
Fire extinguisher
Dust mask with filters
Ear defenders
Goggles with face shield
Zinc primer and Etch primer
Butt welding clamps
Electric belt sander
Leather apron
Steel rule
Scribe and pick set
Air chisel
Random orbital sander and discs
Many thanks, Dave :)
*Edited to include recently bought items.
Edited by Daviewonder, 24 September 2016 - 09:07 PM.
#2 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,042 posts
Posted 28 May 2016 - 10:19 PM
Ear defenders, Makes grinding and using air tools so much better.
#3 BusheyTrader
BusheyTrader
  • 481 posts
  • Local Club: Nope
Posted 28 May 2016 - 10:22 PM
Cleco pins. For positioning panels being spot welded / plug welded
Power file belt sander for grinding down welds in awkward areas. Silverline prepared over B&D.
Die Grinder bits. Also for grinding down welds in awkward areas but these fit in a drill
A proper dust mask to keep grinding dust out of your lungs.
Fire retardant overalls when welding
Lots of practice on steel off cuts
Lots of patience - not always readily available
Edited by BusheyTrader, 28 May 2016 - 10:27 PM.
#4 mini-auto
mini-auto
  • Just Joined
  • 102 posts
Posted 28 May 2016 - 10:24 PM
+1 on ear defenders & patience.
Garage
Weld through primer, etch primer
Seam sealer
Fire extinguisher
Sticking plasters
Radio
jacks, axle stands
#5 Daviewonder
Daviewonder
  • 1,020 posts
Posted 28 May 2016 - 10:43 PM
Thanks for the fast replies.
I see there are a few bits I've missed. Can anyone recommend me a dust mask please?
#6 smudger068
smudger068
  • 344 posts
Posted 29 May 2016 - 07:59 AM
Atco do a good one for about £20-30 you actually breathe fresh air can come with a different range of filters, theres a wholesaler in Basildon, Essex. Im sure you could order or advise with a quick google search
#7 MrBounce
MrBounce
  • 2,663 posts
Posted 29 May 2016 - 08:54 AM
Proper welding gauntlets are a must. Cheap ones from Machine Mart are only £4.
#8 sledgehammer
sledgehammer
  • 3,109 posts
Posted 29 May 2016 - 09:24 AM
ear defenders can also stop sparks getting in the ear - painful
old leather jacket put on back to front when welding upside down
something to lay on / kneel on & a rag in water to put out under seal fires
bright directional light that can be clamped near welding site , so you can see with mask down before striking up
a place to store flammable's , out of the way of welding
- IMPORTANT - someone else near the garage incase something bad happens - don't rely on a mobile somewhere in the garage
my neighbour was working on a pickup in a garage next door to me
he knocked it off axle stands while jacking it up to get it higher , broke his collar bone & slight crush injury , but was pinned under car for a while
mobile was on table at other end of garage , everyone was at work so no one to help , think he cause himself more damage dragging his self out
Edited by sledgehammer, 29 May 2016 - 09:27 AM.
#9 BusheyTrader
BusheyTrader
  • 481 posts
  • Local Club: Nope
Posted 29 May 2016 - 09:27 AM
Top tip on the welding gauntlets there......
Fire retardant overalls needn't be expensive. I've picked my last 2 pairs up at shows for £20 or less. They will hold back welding spatter but don't expect them to stop a big ball of molten metal if you're welding from underneath. Most of the welding masks don't cover the top of the head. A welder's cap can stop spatter from stinging your scalp.
#10 smudger068
smudger068
  • 344 posts
Posted 29 May 2016 - 10:11 AM
A good bottle of factor 50 suncream to stop UV burning your skin, common burn through collar around your neck
#11 CityEPete
CityEPete
  • 3,920 posts
Posted 29 May 2016 - 08:31 PM
Good thread, I'm about to embark on a weldathon and that list is handy. Good luck.
