Top Speed From Gbox Ratios
7 replies to this topic
#1 Dusky
Dusky
  • 5,322 posts
Posted 31 May 2016 - 08:05 AM
Hi
Looking through old stuff I found the old gbox spec sheet from my dads mini.
It has a jack knight sccr box, my dad wrote "1.087" ratio next to it, tho that might be the drop gear ratio?
And it has a 4.9 fdr. Id like to calc the top speed in 4th gear @8.5 k rpm, but these ratios arent featured in guessworks calc and when I tried 50 ish km/h was the top speed, Wich cant be correct ( couldnt win championchips with that!:P)
#2 nicklouse
  • 18,697 posts
Posted 31 May 2016 - 08:11 AM
generally the 4th gear is a 1 to 1 of the input speed on most Mini Boxes (commonly called direct drive)
then you have the reduction of the FD ratio and then there is the effect of the drop gear ratio to consider for the input RPM which is unknown but could be a 1:1.1 as that was a common ratio.
#3 Cooperman
  • 23,326 posts
Posted 31 May 2016 - 08:47 AM
Dusty, with a 3.76 FDR you get 14.7 mph/1000 rpm in 4th
So the calculation is:
14.7 × 3.76 ÷ 4.9 = 11.28 mph/1000 rpm.
With a 1.087 drop gear ratio, assuming it is set to reduce the overall gearing:
11.28 ÷ 1.078 × 8500 RPM = 88.2 MPH
I hope this helps.
#4 nicklouse
  • 18,697 posts
Posted 31 May 2016 - 09:02 AM
I am guessing that is with a 165/70-10? but the tyre and wheel combo is not known?
guessing slicks? 20" or 21" diameter?
like I said there is not really enough info to give speed.
#5 Cooperman
  • 23,326 posts
Posted 31 May 2016 - 09:28 AM
I could only use a known figure as a start point. With a 10", 12" or 13" running normal road tyres that figure will be correct to +/- 4%. So the speed at 8500 in top will be 84 and 92 mph.
Dusty, if you let me know what wheel/tyre combination you are running and what the rolling radius is I can get closer with a figure.
#6 Dusky
Dusky
  • 5,322 posts
Posted 31 May 2016 - 11:22 AM
Hi! Thanks for the Quick replies, running 13 inch avon slicks. The numbers on them are 6.0/19.5-13 and 4902 WTIG
#7 nicklouse
  • 18,697 posts
Posted 31 May 2016 - 11:51 AM
19.5 is the diameter in Inches.
so 165/70-10 circumference 1523.7mm
19.5" slick circumference 1556mm
#8 Cooperman
  • 23,326 posts
Posted 31 May 2016 - 02:26 PM
Thanks for the numbers Nick
So in round figures that means the speed increases by 2% giving a new theoretical max of almost exactly 90 mph at 8500 rpm
