Posted 31 May 2016 - 01:47 PM
Posted 31 May 2016 - 04:10 PM
Posted 01 June 2016 - 11:26 AM
Give me a shout or call if you get a bit stuck, just need your year of Mini really, and I can more than likely sort your problem.
Posted 01 June 2016 - 12:04 PM
Agree wit Batmini's pic of the fam7821 regulator. The Master connections depend on which master you have. The stepped bore, yellow band, cylinder can only be used in a front rear split with the rear on the lower outlet.
It's convention to put the front on the bottom otherwise, but it's not as critical.
Posted 02 June 2016 - 04:20 PM
Posted 04 June 2016 - 04:52 PM
Also tagged with one or more of these keywords: brakes
Mini Technical Sections →
Problems, Questions and Technical →
Yellow Tag Brake Master Cylinder QuestionsStarted by John K Series , 12 Mar 2026 |
Time To Bleed The BrakesStarted by Murrayup , 11 Mar 2026 |
Clutch And Fan Noise From Newly Rebuilt 1380 Engine.Started by sam138 , 19 Feb 2026 |
1968 Cooper Parts NeededStarted by Neilmr , 14 Feb 2026 |
New Rear Drums Locking/bitingStarted by SteadyEddie , 11 Feb 2026 |
