On the mpi there is a square ended threaded bar to tension the alternator belt? anyone know if this needs a tool and where from as a socket doesn't seem to grip it enough?
tool for tightening alt belt on an mpi?
Gibbo
, Aug 29 2006 02:53 PM
1 reply to this topic
Posted 29 August 2006 - 02:53 PM
Posted 29 August 2006 - 05:05 PM
Don't know what the proper tool is for it, but i have always used a normal socket jammed over it, i think it was a 13mm 12 sided socket if i remember correctly. Make sure you undo the nut on the black tensioner wheel a little bit, and it should turn quite easily....
