Hello all,
I am currently stripping down a 1998 MPI and I now need to take out the brake servo. This involves draining the brake fluid. what is the best way of doing this? I find the Haynes manual a bit vague on the process.
Many thanks
Posted 01 June 2016 - 02:24 PM
Hello all,
Many thanks
Posted 01 June 2016 - 03:21 PM
Posted 01 June 2016 - 05:02 PM
great, thanks. will this drain the whole system?
Posted 02 June 2016 - 08:13 AM
Posted 02 June 2016 - 05:15 PM
If you are only doing this to safely install/replace a servo, just drain the system as Steve suggested. That will leave the other brakes lines full of fluid. That in turn will make bleeding the system easier once the new servo is installed. Avoid blowing through the lines to all four wheels if you don't have to. Once the servo is installed you will need to bleed the whole system anyway. Bleeding a system that has only air in it can be time consuming and frustrating if things don't go well.
Posted 03 June 2016 - 10:24 PM
thankyou for the advice.
