Mini Neon Tart Up
22 replies to this topic
#1 neon1991
neon1991
  • 77 posts
Posted 02 June 2016 - 09:07 AM
so here he is! I was looking to get my old mini back but missed out on the sale...  I found this one up the road from me and decided to go and have a look at it.  Its got a pretty badly fitted front end,  over sills hiding a lot of rust and the rear subframe is toast.
Attached File  bumble.jpg   62.06K   6 downloadsAttached File  mini home.jpg   44.29K   7 downloads
I've removed the rear subframe and found that the heel board mounts are pretty good,  a 10p hole at the top edge on one side what will need looking at but thats about it.  There are a few crusty bits where brake pipe clips were but nothing major.
Attached File  rear mounts 2.jpg   29.06K   4 downloads
Attached File  rear mounts.jpg   32.65K   1 downloads
not great pics but it was getting a bit dark.
the boot floor is also gone in the rear corners,  as are the valance closing panels and the valance.
Attached File  crusty floor.jpg   38.38K   7 downloadsAttached File  hole.jpg   46.19K   3 downloadsAttached File  too far gone.jpg   44.33K   4 downloads
 the new panels and subframe should be here this week so I can start sorting the back end out.
Dave
#2 neon1991
neon1991
  • 77 posts
Posted 20 June 2016 - 09:51 AM
So back at it this weekend and managed to get the boot floor chopped out along with the hinge panel, valance and corners and corners.  there was not very much worth saving from the back end :(
Attached File  rust.jpg   86.42K   9 downloads
then set about sorting out the new panels.  Magnum boot floors are rubbish!  they managed to get the wheel well shape but when this is matched up,  it leaves too much lip on the rear (about an inch. taking it all an inch in means youre left with an off shaped wheel well.  Ive matched up the wheel well at will just cut the excess off and drill new bumper holes.
Attached File  boot floor.jpg   72.01K   11 downloads
the welder wasnt happy to begin with but it's getting there.  it's not too bad considering i'm using gasless wire
Attached File  weld.jpg   59.86K   13 downloads
then played with the jigsaw that is the rear end panels  O_O
Attached File  new bits.jpg   63.56K   16 downloads
#3 GTIAlex06
GTIAlex06
  • 1,562 posts
Posted 20 June 2016 - 12:26 PM
Looking good similar to my project following with interest
#4 neon1991
neon1991
  • 77 posts
Posted 20 June 2016 - 01:19 PM
Cheers! yup,  all the usual rot.  after ive done the back end then it's boht inner and outer sills.  Then ive got a the front end to do which looks like bodge after bodge round there.  all good fun though!
#5 James_eaton_thewholething
  • 1,063 posts
Posted 20 June 2016 - 01:53 PM
I did the whole of my welding with gasless wire. I found every now and the welder had issues every now and then. Good looking project though
#6 neon1991
neon1991
  • 77 posts
Posted 20 June 2016 - 02:29 PM
Yeah,  it's a bit messier than with gas but the welder came with a massive reel of the stuff so I thought I'd use it.  I don't mind it to be honest.
#7 James_eaton_thewholething
  • 1,063 posts
Posted 20 June 2016 - 06:04 PM
It's nothing a good use of a flap disc won't solve.
#8 neon1991
neon1991
  • 77 posts
Posted 15 August 2016 - 09:03 AM
sorry for the lack of updates but Ive been busy shopping and stockpiling parts for this mini that keeps on chucking surprises at me.
So first on the shopping list was a spit / rotisserie.  I picked this up second hand off ebay, no pics yet as i haven't put it together.
then i bought a pair of inner and outer sills from m-machine as mine have been covered with over sills.  a quick look down a hole I made, confirms that the inners and the original outers are shot.
Attached File  new sills.jpg   21.97K   14 downloads
then I set about removing the engine and subframe... I toyed with the idea of dropping the whole lot on the floor but with a hired crane, found that out the top was a doddle.. even the clutch split pin was fairly easy.
engine out and a quick clean up
Attached File  grubby.jpg   46.46K   6 downloads
Attached File  sparkly.jpg   53.88K   7 downloads
in the process of doing all this,  I found that most of the gaiters were split, knuckle joints are knackered and the wheel bearings were pretty loose.  it's had new breaks fitted so not sure if someone just didnt tourque it up properly... they run smooth enough.
one last thing i noticed.  there was no tear drop mounts on the front of the subframe.  there are holes in the front panel for them,  just nothing fitted. To top this off,  the front panel was only welded at the wings.. the bottom part was held to the inner wings with self tappers :(
#9 neon1991
neon1991
  • 77 posts
Posted 22 August 2016 - 08:26 AM
got the mini mounted on the spit this weekend. so I can now start on chopping out the sills.
Attached File  spit1.jpg   92.2K   4 downloads
Attached File  spit 2.jpg   66.11K   3 downloads
Attached File  spit3.jpg   64.86K   3 downloads
#10 neon1991
neon1991
  • 77 posts
Posted 22 August 2016 - 08:28 AM
14034935_10154484439408593_9597034241452
#11 neon1991
neon1991
  • 77 posts
Posted 24 August 2016 - 09:11 AM
will this rust ever end!!!!
a panel came off in my hand along with most of the hinge panel and a very dodgy patch on the inner arch  :lol:
14067568_10154491080643593_3469705091201
14022244_10154491080678593_5471666241152
#12 MacGyver
MacGyver
  • 1,028 posts
Posted 24 August 2016 - 11:14 AM
Good thing it's not an important part...
Oh... No... Wait... 🤔
Good luck with the build! 😎
#13 neon1991
neon1991
  • 77 posts
Posted 24 August 2016 - 04:31 PM
Oh... No... Wait...
haha! thats exactly what I thought when it all evaporated in front of me :D
#14 MacGyver
MacGyver
  • 1,028 posts
Posted 25 August 2016 - 06:27 AM
Oh... No... Wait...
Mine had the sill do that, but I was driving it... 😬
Edited by MacGyver, 25 August 2016 - 11:00 AM.
#15 neon1991
neon1991
  • 77 posts
Posted 31 August 2016 - 08:06 AM
No much of an update but I got a big box from minispares yesterday which contained the door steps and flitch panels I've been waiting for.  so I proceeded to chop the cancer out.
what a mess :D
14202693_10154513438693593_2595398357287
over sills over the originals... there's nothing left of the jacking point and the crossmember looks a little bit sad at the ends
14199694_10154513438753593_2371592731993
14199428_10154513438798593_4014798271216
