Mini Neon Tart Up
22 replies to this topic
#16 neon1991
neon1991
  • 77 posts
Posted 05 September 2016 - 08:52 AM
3 floors for the price of 1
14102472_10154526853208593_7728317078003
inner arch hasn't fared too well
14238233_10154526853048593_3945562545795
but I have made some progress..!
subframe mount and inner and outer sill now on :)
14202620_10154530462313593_2568811987741
still need to add the bottom part of the b-post and tidy up and finish off the bottom of the a-post.  then I'm fitting the closing panel at the subframe mount and covering the whole lot with the doorstep panel that goes from the apost back to the arch.
Edited by neon1991, 05 September 2016 - 08:56 AM.
#17 neon1991
neon1991
  • 77 posts
Posted 10 October 2016 - 09:00 AM
this has to be the slowest resto ever!  O_O
anyway,  had a month off it so decided to make a bit of progress yesterday.
managed to get the door step in.  I didn't finish dressing down the welds as I had to pack up so sprayed it over with a coat of zinc primer.
14516576_10154635331478593_7177002052477
#18 neon1991
neon1991
  • 77 posts
Posted 20 March 2017 - 10:10 AM
not sure adding URL's from facebook seems to have worked very well as they've all vanished lol.
so after a couple of months off i've managed to do fit inner and outer sill to the other side.  new flitch panels to both sides,  a new scuttle,  new door step, new wings and A panels and even managed to reuse the front panel that was fairly new and held on with self tappers!
thank god the door still fits! :D
Edited by neon1991, 20 March 2017 - 10:11 AM.
#19 neon1991
neon1991
  • 77 posts
Posted 02 May 2017 - 09:24 AM
got a bit more work done this weekend.  both subframes in and it's back on it's wheels.
under sealed and seam sealed the underside and arches etc and stone chipped the lot.
turned my attention to the doors.  The drivers door is not fitting well,  very tight at the back and a huge gap at the a panel.  the door frame it'self was in a bad way so will have to look what it looks like now that it's all repaired.
#20 neon1991
neon1991
  • 77 posts
Posted 29 May 2018 - 08:56 AM
okay so it's been a while!!  :shy:  and after a lot of graft the last two weekends I'm now here.  the reason for such a delay was due to the fact that the asbestos garage that I was working in,  decided to fall down almost around my ears.  so I had to build a new garage too :D
so here we are now
#21 johnR
johnR
  • 2,318 posts
Posted 29 May 2018 - 11:18 AM
Great paint effect - I hope you put the lace curtains back up!
#22 neon1991
neon1991
  • 77 posts
Posted 29 May 2018 - 11:34 AM
haha... a little bit milky looking now and I had to cut two chunks out of the middle for the bonnet stripes.. :D never done it before but happy with the result :)
#23 neon1991
neon1991
  • 77 posts
Posted 12 June 2018 - 01:33 PM
Attached File  rear end.jpg   95.08K   2 downloads
front and rear screens in,  just waiting for my filler tool to show up.
I'm hoping this is the final stretch
Attached File  side done.jpeg   107.5K   1 downloads
