Heater Unit
7 replies to this topic
#1 jackuig
jackuig
  • 39 posts
Posted 02 June 2016 - 03:03 PM
Hello everyone :)
I'm looking to replace the heating unit in my '73 clubman, but trying to get my hands on one has been harder than I thought! Anyone know where I could get one?
I have seen a good condition second hand unit for sale, but its from a '94 mini 35. Will this fit my '73?
Any info will be much appreciated! :)
#2 JBW
JBW
  • 157 posts
  • Local Club: Mini Fixers
Posted 02 June 2016 - 09:19 PM
Not sure which is the correct one for your car, but as far as I know by the 90's, the coolant inlet & outlet pipes were vertical on the left side of the heater unit, the earlier ones had the pipes on the right hand side/
My car is a 1993 & did have the wrong heater, since changed for the correct type.
#3 jackuig
jackuig
  • 39 posts
Posted 02 June 2016 - 09:26 PM
Ah okay, so looks like I'll have to get one age specific, rather than just being able to fit any mini one then.
Thanks! :)
#4 JBW
JBW
  • 157 posts
Posted 03 June 2016 - 08:48 AM
If you look carefully at your existing heater & determine where the water pipes connect, you should then be able to find one on Ebay or similar, there are several S/H Mini parts sellers as well, one that springs to mind is http://www.minimail.co.uk/parts/
#5 Ethel
  • 26,074 posts
Posted 03 June 2016 - 10:24 AM
Any could be made to fit, the main differences are the size of water and demister pipes.
#6 JBW
JBW
  • 157 posts
Posted 03 June 2016 - 11:25 AM
Attached File  Old heater.jpg   69.13K   17 downloadsAgree could be made to fit, the wrong heater was fitted in mine when i got it, the pipes were a mess, one across the front of the heater, the other was always getting caught by my left foot when using the clutch.
#7 Itsaminithing
Itsaminithing
  • 853 posts
  • Local Club: Not One Worth Mentioning
Posted 03 June 2016 - 11:39 AM
For identifying Part Numbers, -what was originally fitted, -& what the part looks like you'll find the Somerford Mini site really handy-
http://www.somerford...page=page&id=99
http://www.somerford...age=page&id=100
As Ethel stated any heater unit can be made to fit IF you're prepared to spend time &/or money.
If the unit is original & you want to keep the period look you could always do some research into just replacing the heater core or fan maybe with a more modern or new part.
#8 jackuig
jackuig
  • 39 posts
Posted 03 June 2016 - 12:49 PM
Thanks guys! Very helpful :)
Will look into the original parts, hopefully avoid having to change any piping
