Rear Subframe Mounts
7 replies to this topic
#1 Mayfair94
Mayfair94
  • Just Joined
  • 63 posts
Posted 02 June 2016 - 03:09 PM
Hi, I have just purchased a Rover Mini (Mayfair 94) which I am looking to try and restore to it's former glory! I purchased it knowing it failed it's MOT, however I am not a mini expert so was looking for some guidance.
It failed for the nearside and offside rear subframe mounts being 'excessively corroded in prescribed area'. I am trying to work out if this requires a subframe, just the mounts or something a whole lot worse?! I would like to get it back on the road fairly quickly but any guidance on how to rectify this would be greatly appreciated.
Many Thanks,
Chris
#2 nicklouse
  • 18,998 posts
Posted 02 June 2016 - 03:12 PM
it could be anything. ask the tester why they failed it.
something is rusty. subframe or body.
#3 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,168 posts
  • Name: Neil
Posted 02 June 2016 - 03:54 PM
It sounds like the heel board ends are corroded but pictures would help us to give you a better picture of what needs doing.
#4 Carlos W
Carlos W
  • 10,115 posts
Posted 02 June 2016 - 03:56 PM
Have a look at this area
#5 Mayfair94
Mayfair94
  • Just Joined
  • 63 posts
Posted 02 June 2016 - 04:35 PM
Cheers guys, will have a look and take some pics when I get it on some axle stands. Will post on here soon.....
#6 Icey
Icey
  • 1,574 posts
Posted 02 June 2016 - 09:19 PM
As Carlos has pointed out - heelboard is a common corrosion hotspot but also check the boot floor where the rear trunnions are bolted up.
Edited by Icey, 02 June 2016 - 09:19 PM.
#7 Mayfair94
Mayfair94
  • Just Joined
  • 63 posts
Posted 03 June 2016 - 06:47 AM
Well the boot floor has holes in it I know, from what I could see mostly towards the rear (see pic). I pick the car up on Monday so will have a closer look at this area. When I went to see the car I had a very quick look at the subframe which looked like it had some surface corrosion but in fairly good nick. When I get the car i will have a closer look underneath.
Could these holes in the boot be classed as rear subframe mounting? I saw on mini spares they sell a repair patch for the area in question.....
#8 nicklouse
  • 18,998 posts
Posted 03 June 2016 - 08:13 AM
 and yes that could be it or one of many.
