Recommendation On Rust Treatment Products
13 replies to this topic
#1 xMarshyy
xMarshyy
  • 23 posts
Posted 02 June 2016 - 08:34 PM
Slight rust starting on the inside of the door, just looking to slow it down for the time being. What are peoples recommendations on rust treatment products?
I've been looking at Kurust and rust remover gel by Hammerite.
#2 Down&Out
Down&Out
    The King Of Retro Cool
  • 4,853 posts
Posted 02 June 2016 - 09:04 PM
Ive always found Kurust to work, hammerite stuff not used but I had a dip by them that never worked so i'd go for a quick kurust and paint over just to slow it.
#3 FlyingScot
FlyingScot
  • 2,664 posts
Posted 02 June 2016 - 09:09 PM
Deox C or Deox gel by Bilthamber then Electrox and finally paint. Top off with Dynax UC.
No I dont work for Bilthamber or have anything to do with them but their stuff is top notch and British made, plus they give advice.
FS
#4 ger
ger
  • Just Joined
  • 233 posts
  • Local Club: M4 Minis
Posted 03 June 2016 - 06:04 AM
Got to agree with FlyingScot,  + epoxy primer before any topcoat. Just about tried everything doing my GT resto.
Ger
#5 pete l
pete l
  • 1,409 posts
Posted 03 June 2016 - 06:21 AM
FS
+1 on BILTHAMBER, you only have to try it out once to be asstonished by the results. forget about the other junk from halfords that transforms the rust into a stable compound. BILTHAMBER REMOVES ALL RUST, it is wicked stuff
Pete
#6 Stu.
Stu.
  • 912 posts
Posted 03 June 2016 - 09:18 AM
After rust removal / treatment I'd also give it a coat of phosphoric acid after you've keyed the surface, let it dry then use epoxy primer and top coat. Make sure the area is completely encapsulated in paint both sides. If air can't get to it, it can't continue to corrode.
Metal needs both water and air to corrode. If ones not in contact with the metal it can't happen.
Epoxy primers are best to use as they're waterproof unlike other primers, except for Bilt Hambers Electrox.
While rust 'treatment' is an important process, complete encapsulation after treatment is the key factor in preventing its progress.
Edited by Stu., 03 June 2016 - 09:18 AM.
#7 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,090 posts
  • Name: Neil
Posted 03 June 2016 - 10:53 AM
Another one for Bilt Hamber Deox. I used Krust a lot and it does work on light surface rust but for stuff that's a bit deeper then the Bilt Hamber works well.
HOWEVER if the metal is deeply pitted then it's too late, that will need cutting out and fresh metal welding in as mini panels are thin to start with.
#8 BusheyTrader
BusheyTrader
  • 481 posts
  • Local Club: Nope
Posted 03 June 2016 - 11:10 AM
+1 for Bilthamber products. The real test will be when you look back in 25 years time but the results on Deox C for rust removal are pretty impressive. Their weld through zinc primer and electrox seem pretty robust as well. Not connected with them, just bought their products over the last few years. Have a look at their website.
#9 xMarshyy
xMarshyy
  • 23 posts
Posted 06 June 2016 - 02:24 PM
FS
Ger
FS
Pete
Looks like I'll be putting an order in with Bilthamber. Thanks for all your opinions :)
#10 jackuig
jackuig
  • 39 posts
Posted 06 June 2016 - 03:18 PM
Wax oil on the underside of the car, very good for preventing rust
#11 Steve220
Steve220
  • 5,076 posts
  • Local Club: BMC
Posted 07 June 2016 - 08:34 AM
Waxoyl is crap. Much better products out there now
#12 Mini 360
Mini 360
  • 4,933 posts
  • Local Club: Independent
Posted 07 June 2016 - 08:57 AM
Agreed.  Might as well melt a candle and throw the wax from that on your car.  Both as bad as each other and far better products out there nowadays.
#13 pete l
pete l
  • 1,409 posts
Posted 07 June 2016 - 09:18 AM
How about telling us what is better then ? rather than just saying it's crap !
#14 Steve220
Steve220
  • 5,076 posts
  • Local Club: BMC
Posted 07 June 2016 - 09:30 AM
It's mentioned in this thread already. Dynax UC.
