Tail Lights Come On Even When Switch Is Off
12 replies to this topic
#1 Readers14
Readers14
  • 441 posts
Posted 03 June 2016 - 04:23 PM
As per the title, I noticed my tail lights are on even when the switch is off.
Any ideas?
It's a '94 Sprite.
#2 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 03 June 2016 - 04:57 PM
Does this happen with the ignition off? (taking a feed from a faulty brake switch?)
#3 Readers14
Readers14
  • 441 posts
Posted 03 June 2016 - 05:49 PM
Happens when key is in ignition & turned to position 1. Engine not running.
When key is removed, it they turn off.
Edited by Readers14, 03 June 2016 - 05:51 PM.
#4 ChopperHarris
ChopperHarris
  • 1,139 posts
Posted 03 June 2016 - 06:02 PM
Unplug the switch and see if they go off....indicates faulty switch if they do
#5 Readers14
Readers14
  • 441 posts
Posted 03 June 2016 - 07:13 PM
Where's the switch located?
I'll try it later tonight.
#6 Readers14
Readers14
  • 441 posts
Posted 03 June 2016 - 07:57 PM
Found the switch, unplugged one of the connectors & the the tail lights turn off!
Thanks for the help!
I'll order a new brake switch.
#7 Ethel
  • 26,104 posts
Posted 03 June 2016 - 10:04 PM
It might just need adjusting.
#8 ChopperHarris
ChopperHarris
  • 1,139 posts
Posted 04 June 2016 - 12:09 AM
Ah some confusion, you originally said tail lights, not brake lights. Actually the same applies but as Ethel said, the brake light is adjustable. The rocker light switch is throw awayble ;o)
#9 Readers14
Readers14
  • 441 posts
Posted 04 June 2016 - 08:22 AM
So if I adjust the brake light switch will it turn the tail lights off?
Or do I need a new rocker light switch?
#10 tiger99
tiger99
  • 8,584 posts
Posted 04 June 2016 - 09:26 AM
Do you have a hydraulic brake light switch, or a mechanical one in the pedal area? The hydraulic switch, maybe only early cars, is throw - away, some but not all mechanical ones are adjustable. Hopefully yours is. The switch should be pressed only when the pedal is fully up. You will see what I mean when you get down there for a look. Fortunately it is nowhere near as bad as the clevis pin in that area!
#11 Readers14
Readers14
  • 441 posts
Posted 04 June 2016 - 10:02 AM
It is the mechanical switch on the brake pedal.
I'll have look later today to see if I can adjust it.
I've ordered a new one anyway, just in case. They're only a few quid.
#12 Ethel
  • 26,104 posts
Posted 04 June 2016 - 10:13 AM
If unplugging the brake light switch cured it, I'd expect that was the issue. It could look like tail lights if it was barely making contact, increasing the resistance - a new switch may be wise as that'd eat the contacts. If it was the tail lights, you'd expect the number plate and side lights to come on too.
#13 Readers14
Readers14
  • 441 posts
Posted 04 June 2016 - 07:19 PM
The position of the brake switch has been adjusted & all is fine now.
The lights turn on when the pedal is pressed.... As it's supposed to! ;)
