Morning guys what coolant are you using these days is water and antifreeze the normal cheers.
Coolant
slowy
, Jun 05 2016 08:36 AM
4 replies to this topic
Posted 05 June 2016 - 08:36 AM
Posted 05 June 2016 - 09:42 AM
Yeah go for the glycol blue stuff and change it every couple of years. It's plenty cheap enough
Posted 05 June 2016 - 10:08 AM
The above, unless you have an MPI that's run OAT. Worst you can do is mix the two.
Posted 05 June 2016 - 10:17 AM
Better idea is to use deionised water and coolant rather than standard tap water, causes less issues with corrosion and whatnot
Posted 05 June 2016 - 10:39 AM
Cheers for replying blue is the way then .
