Selling my Scott Voltage FR10 as I haven't ridden it for a while and I fancy a new bike in the future. I believe the frame is the short size, I am 5' 10/11" and technically the bike is a little small for me but I never found it an issue, just made the bike easier to flick about.
The bike is in pretty good condition, has been used well and has taken all I've thrown at it and it hasn't complained. New frame bearings were fitted around a year ago, along with a new headset. Bottom bracket is really smooth and the wheels have no play.
1 issue which I have fixed/repaired was with the current rear dropout. The thread in one of the original allen fixings stripped in the dropout, so I made a brass spacer and have used a nut and bolt to replace the original fixing as shown in the photos. This does not affect the way the bike rides and doesn't get in the way of the wheel or brake.
The bike has been upgraded a fair amount, it has Renthal Fatbars and a Renthal Duo stem, a Renthal 36t front chainring, E-Thirteen LS1 chain device, Hope seatclamp, a SRAM 9sp DH cassette (meaning with the standard 10speed shifter and rear mech, there is a spare click between 1st and 2nd gear), Shimano Saint cranks, with BB80 bottom bracket and Nukeproof pedals. Also has a mucky nutz front fender fitted and Maxxis Minion DHF tyres which are relatively new and have plenty of life left in them.
The Fox 36 forks have 180mm of travel, they are the Van Fit RC2 model meaning they are coil sprung (fitted with green spring). They are in relatively good condition, with some normal scuffs on the lowers but the stanchions are unmarked. These are the non-kashima version. I will include the remains of a TF Tuned Refresh Kit from when I serviced the forks and also a spare fork coil spring (blue). The rear shock is a Fox RC2 which is fitted with a 300lb spring. Has never let me down and works really well.
Wheels were rebuilt with all new DT Swiss spokes and nipples last year, running airwave DH tubes.
Also included is the additional frame dropouts and shock mounts which allow a shorter wheelbase and shock length if the bike is to be setup as a slopestyle bike (for 140mm rear travel). All manuals are there, the original bars and stem which look to be unused (I haven't used them) and also a set of new handlegrips. I will also include the old 10speed cassette which is well used but can be refitted if wanted.
This bike has served me really well, I've owned it since 2013 and I simply want an upgrade. The bike rides great. As mentioned in the title, the bike does not have any brakes.
£750 collected from near Halstead, Essex. Open to offers.
Thanks!
Edited by RooBoonix, 14 June 2016 - 03:54 PM.
