Cv Boot Clips Pot Joint
4 replies to this topic
#1 crn1969
crn1969
  • 114 posts
Posted 12 June 2016 - 04:14 PM
Am in process of replacing cv boot to pot joints new cv boot kit comes with clips with ear type tab that you crimp.question is this the small clip (which i think goes inside the boot by turning insude out fitting it then flipping boot over it?)will this type of clip protrude when done up fully and if so wont it fowl the driveshaft/or inside of potjoint whilst in motion(obviously i am aware it is all spinning together)maybe a plastic cable tie is better?any experience or problems with this? Cheers.
#2 cal844
cal844
  • 9,646 posts
  • Local Club: TFMOC
Posted 12 June 2016 - 04:52 PM
I use a cable tie from a reputable source(not the cheap rubbish) on the large end of the gators, on the small ends I use the clips
#3 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 12 June 2016 - 05:13 PM
I've just done mine before putting the engine back in. The small clip crimps well (and doesn't foul the boot) as I have the proper crimping pliers, if you don't, I suggest you use a quality cable tie. The large one I got in my kit, even with the proper pliers was not a tight fit so I ended up using a cable tie.
#4 Coxie
Coxie
  • 461 posts
Done mine with the metal crimps as you say with no problems.
#5 mk1leg
mk1leg
  • 9,343 posts
Posted 12 June 2016 - 05:16 PM
I use metal cable ties much thinner then plastic,,,,, https://www.amazon.c...0?ie=UTF8&psc=1
