Wrapping Manifold - Yes Or No
12 replies to this topic
#1 Kt1966
Kt1966
  • 232 posts
Posted 15 June 2016 - 04:24 PM
Currently piecing together a van which has a reasonable spec 1380 in it.
Question is should I wrap the manifold and if so with what ? It's a Maniflow with LCB
Many thanks
#2 Steve220
Steve220
  • 5,075 posts
  • Local Club: BMC
Posted 15 June 2016 - 04:41 PM
Definitely, especially whilst it's off! Not entirely sure how much you'd need for a manifold. I get mine from merlin
https://www.merlinmo...ts/exhaust-wrap
#3 racingbob
racingbob
  • 3,061 posts
Posted 15 June 2016 - 04:44 PM
make sure you get the good stuff
#4 Mini ManannĂ¡n
Mini ManannĂ¡n
  • 2,860 posts
  • Local Club: man Estate
Posted 15 June 2016 - 04:45 PM
Mine's been wrapped for two year without an issue, starting to get a bit raggedy now though!
#5 skoughi
skoughi
  • 1,199 posts
  • Local Club: Shetland classic car club
Posted 15 June 2016 - 05:20 PM
Thought about wrapping mine but decided not to going by what a lot of folk said about it. I've now burnt off paint on the lower bulkhead from the exhaust heat! Kinda wishing I'd done it now!
#6 Kt1966
Kt1966
  • 232 posts
Posted 15 June 2016 - 05:49 PM
That's really helpful - many thanks. I'd really like to avoid burning paint off....(given what it's cost so far!)
If I buy from Merlin, what's the best sort to get ?? - don't suppose I'll need very much and does it stay on ok ??
#7 Richie83
Richie83
  • 1,495 posts
Posted 15 June 2016 - 06:18 PM
mine is held on with metal cable ties. Seems to do the job. You just need to keep the wrap tight and secure as you go.
Edited by Richie83, 15 June 2016 - 06:20 PM.
#8 Wise Old Elf
Wise Old Elf
  • 1,655 posts
  • Local Club: Club Lotus
Posted 15 June 2016 - 08:05 PM
Has anyone used a DIY ceramic coating that works well?
#9 tiger99
tiger99
  • 8,584 posts
Posted 16 June 2016 - 10:54 AM
Why not have a professional ceramic coat, which is guaranteed to work well. Zircotec comes to mind. As far as I am aware, ceramic coatings are not a DIY proposition because they need to be applied by plasma spray if they are going to bond properly.
#10 nicklouse
  • 18,724 posts
Posted 16 June 2016 - 10:58 AM
may as well buy three manifolds for the cost.
, I've spoken to Zircotec and its £345 plus vat and postage (ouch)
#11 tiger99
tiger99
  • 8,584 posts
Posted 17 June 2016 - 12:56 PM
Ouch indeed! More than I expected, considering how many people use the process. But sometimes you really need to spend money. It just depends on how acute the problem is and how desperately it needs to be solved. At least you get something tangible for the money.
#12 skoughi
skoughi
  • 1,199 posts
Posted 17 June 2016 - 01:33 PM
I've hot heat problems at the back of the engine, bubbled paint, found a couple bits of plastic ducting that I've managed to get fitted to take cold air from the grill around both sides of the engine to the back which will hopefully help. Also thought that a smallish hood scoop would help to blow some much needed cool air down the back of the engine too. I'll probably take the engine back out over the winter to tackle a few things so will either make a heat shield to bolt too the bulkhead or fix on some sort of heat resistant cloth, like asbestos but obviously not!
#13 tiger99
tiger99
  • 8,584 posts
Posted 17 June 2016 - 05:19 PM
It is largely radiant heat, so you need something reflective as well as insulating. Heatmap is one such thing, for going on the bulkhead in sheet form.  Try www.carbuildersolutions.com
