57 Plate Cooper S Tractor Noise
4 replies to this topic
#1 Sianny
Sianny
    Starting My Mini Up
  • 2 posts
Posted 16 June 2016 - 06:03 AM
I have a 57 plate cooper s which I've had for about a year. When I start the car in the morning or evening if it's been cold the engine makes a horrendous tractor noise. It usually only lasts a few minutes until the engine is warm but I'm a bit concerned about it. Has anyone else had this issue and what was the problem? Thanks so much!
#2 I hate Brian
I hate Brian
  • 782 posts
Posted 16 June 2016 - 06:29 AM
Hi you need to get the car to a garage (main dealer) this is called the death rattle. The timing chain tensioner is faulty and the chain could skip, this is why you are getting the noise it's a common fault. I'm on my fourth new mini which is a JCW cabriolet and made the dealer change the chain on purchase of the car.
#3 Sianny
Sianny
    Starting My Mini Up
  • 2 posts
Posted 16 June 2016 - 06:41 AM
Thanks for you response! Is it quite a big fix? How much did it cost for you to get yours done?
#4 FlyingScot
FlyingScot
  • 2,664 posts
Posted 16 June 2016 - 07:08 AM
As this is a classic mini forum, you might be better having a search on mini2 or totalmini
Moving to motor mouth section
FS
#5 cal844
cal844
  • 9,660 posts
  • Local Club: TFMOC
Posted 16 June 2016 - 09:43 AM
I'd advise changing the oil pump as well as the chain kit, the amount of issues with these vehicles is crazy!
