I'm wanting to reduce the heat on my LCB. It's in stainless and I've read it's not a good idea to wrap stainless, I've spoken to Zircotec and its £345 plus vat and postage (ouch!). Has anybody seen any other products or got any other suggestions?
Posted 16 June 2016 - 09:33 AM
Posted 16 June 2016 - 09:35 AM
what problem are you trying to "fix"?
Posted 16 June 2016 - 09:37 AM
I'm trying to reduce under bonnet temp and also stop heat transfer onto the bulkhead.
Posted 16 June 2016 - 10:38 AM
what problem is the underbonnet heat "causing"?
put heat shielding on the bulkhead.
Posted 16 June 2016 - 04:32 PM
I'm still in the process of building the engine and I'm trying to pre-empt problems. I assumed I would need to wrap the LCB to stop too much heat after a long run with no air if I was stationary in traffic. It sounds as though you don't think this will be a problem. With my last LCB I noticed the boot on the pot joint cracked several times and assumed it was not helped by excessive heat, also the bulkhead seemed to get very hot. Do you think I don't need to worry?
Posted 16 June 2016 - 06:28 PM
Posted 16 June 2016 - 06:48 PM
Did you wrap them in anything special or just the normal heat wrap because I thought it made stainless brittle?I've wrapped stainless in the past with great results. Also had manifolds zircoated, amazing technology, just damn expensive!
Posted 16 June 2016 - 07:49 PM
Yes stainless is a little more brittle than mild steel, but wrapping should be ok.
Posted 16 June 2016 - 08:40 PM
Posted 16 June 2016 - 11:06 PM
Did you just use normal heat wrap?
Posted 17 June 2016 - 11:10 AM
you might like to check with manufacturer of the manifold, because I think heat wrapping invalidates any warranty.
Posted 17 June 2016 - 05:13 PM
After your post I checked and you're right, it does invalidate the warranty. Thanks
Posted 17 June 2016 - 07:32 PM
Posted 17 June 2016 - 09:05 PM
Does zircotec also invalidate warrantee on stainless manifolds? Does anyone know.
