I live in australia
I understand the logic of connection and I believe that the 3 gauge cluster has some wierd earthing by using the blue printed circuit board.
the wierd thing is that the tacho needle goes right below 10/1000 rpm when started and stays there while running or revved as soon as you turn the engine off it goes back to zero
which is kinda working but not moving.
Checked if the needle is stuck or something blocking it but it can be move as it should manually by your finger.
Any more bright ideas?
Hi there.
You know this could just be a faulty instrument, as in fact there are electronics inside, which in reality just drive a conventional moving coil instrument.
The electronics include a pulse shaping circuit, integrator circuit, (which provides a varying DC output depending on pulse repetition frequency) and a following DC amplifier.
If the DC amplifier or the integrator circuits go faulty, then the moving coil meter can be fed with a less than adequate voltage, and in fact this could be amplitude limited under certain fault conditions.
This would mean that some movement of the pointer could show between zero and say 1000RPM, with no further movement above that.
Trouble is unless you have electronic test gear available (more than just a multimeter) you will be hard pushed to check this. The best thing to do would be to try and beg or borrow another instrument to try.
