Not long finished getting the car back together and now i'm hit with an oil leak.
The car is a 1995 Sprite 1275 SPI and has only done about 100 miles since getting it back on the road.
Noticed oil under the engine (not an uncommon site for a mini) and found it was coming from the hole in the bottom of the clutch cover.
The clutch did "squeal" a little when being driven and changing gear.
I'm guessing that the clutch oil seal is leaking and needs replacing.
Question is can this be done in the car or am I going to have to taken the engine out?
This topic is locked
