Engines 1100
11 replies to this topic
#1 Albino_Hedgehog
Albino_Hedgehog
  • 341 posts
  • Local Club: Solihull Mini Classic Club
Posted 18 June 2016 - 01:37 PM
I have been offered a choice between two engines,
One of which is an MG 1100 with a 295 Cooper head.
The other is an A+ 998 again with a 295 Cooper head.
What decision should I be making?
#2 Fast Ivan
Fast Ivan
  • 2,910 posts
Posted 18 June 2016 - 02:08 PM
The one with the best history
#3 Cooperman
  • 23,322 posts
Posted 18 June 2016 - 03:46 PM
What is the car going to be used for?
#4 Albino_Hedgehog
Albino_Hedgehog
  • 341 posts
Posted 18 June 2016 - 05:29 PM
Will be used as a fun at times road car, most days.
Not after massive amounts of Pub talk power either!
#5 Cooperman
  • 23,322 posts
Posted 18 June 2016 - 06:05 PM
With sensible cam selection and careful build the 1098 engine will give more torque and the same sort of peak power.
You will need to run a final drive ratio to suit the cam and that should give good acceleration combine with fair cruise speed at around 3500 rpm.
It will help you to understand how to do the cam selection, work out the compression ratio and measure up prior to machining.
#6 Albino_Hedgehog
Albino_Hedgehog
  • 341 posts
Posted 18 June 2016 - 06:30 PM
Thanks for the information.
This nowbrings me to my next question, how easy it to put the 1098 block on a A+/Rod change gearbox?
#7 carbon
carbon
  • 2,590 posts
Posted 18 June 2016 - 06:31 PM
The MG1100 unit will be about 50 years old. If you're lucky it might be in good condition but chances are it will need a rebuild. The A+ 998 may be only be 30 years old, and in my experience the 998's don't seem to wear out and go smoky as quickly as the 1098.
If it's for a quick fun road car the 998 can stand high revs and quite a bit of tuning. But will drive very differently to the 1098. And if you do go for the 1098 make sure it has a crank damper fitted.
Either block should fit onto an A+ or rod change gearbox.
#8 absx2
absx2
  • 919 posts
Posted 18 June 2016 - 07:12 PM
1098`s are lovely motors with loads of lazy torque compared to a 998. If you get a good one a look after it with regular oil changes it will go on and on forever but as mentioned it will probably need a rebuild due to its age and unknown origin. That said a 998 with a 295 head would not have had an easy life so its best to regard both units as needing a rebuild.
If that were the case i would personally go for the 1098 as you don`t need to rev the motor hard and it will hold the gears for longer on the hills and the cabin noise is lower.
But if you want a car to take out and ring its neck like a motor cycle engine the 998 is for you. 998`s are great little screamers that can be ragged hard.
Decisions decisions, i`m glad I have one of each ;)
#9 Spider
  • 15,079 posts
Posted 18 June 2016 - 07:46 PM
FYI, the MG1100 Engine would have been factory fitted with the 12G295.
#10 Albino_Hedgehog
Albino_Hedgehog
  • 341 posts
Posted 18 June 2016 - 09:07 PM
Yeah that's right, I was just pointing out that it still had it haha
#11 JDImini
JDImini
  • 679 posts
Posted 24 June 2016 - 09:02 PM
Hi I too have a 1098 from an 1100 special and an 998, I was interested to read an article from Keith Calver about the 1100 engine and wondered is it worth the effort and money or do I get a 1275 and and spend the money on getting that sorted, or put the 12G295 head on the 998, questions, questions. The 998 has much better history, the 1100, I have no idea about, got off ebay
#12 Cooperman
  • 23,322 posts
Posted 24 June 2016 - 09:33 PM
Best advice is to never fit an unknown engine and gearbox without first stripping and inspecting it thoroughly.
Thinks how manual posts have appeared on here where engines have been fitted without prior stripping and rebuild ingredients as necessarily only to have had told be removes almost immediately.
