Good Morning.
So my mini has been off the road for about 8 years due to losing the bug. But decided to get it back running so I can use it as my wedding car.
Replaced the dizzy, coil, leads and plugs, and carried out an oil and filter change.
With a little bit of fettling I've managed to get it running. Only issue is the oil pressure warning light stays on. I have replaced the oil pressure switch this morning and the light is still staying on. I've only really ran the engine for 20 seconds at most. I've checked inside the rocker cover whilst it was running and cannot see any oil moving around in there.
So, does this automatically mean that the oil pump is kerput? or could it be it just needs to warm up properly?
Its a 1275 cooper block with a missmatch of other bits.
Dan
